Here’s the full verbose logging details for this operation. The AfterGetRows are near the bottom.
[Op Utc=“2018-08-15T14:17:35.9920670Z” act="" dur=“8684.0179” cli="" usr="" machine=“SERVERNAME” pid=“2652” tid=“30”]
[Sql queries=“16” cacheHits=“11” time=“34.6421” qryTypeCount=“4” /]
[DataContext msg=“New DataContext ID:2272107c-6cec-4ad2-9732-5ec73f8dacc3 created on SPID:” /]
[EpiConnection oper=“Opened” spid=“60” /]
[Trigger msg=“Disabling SysUserFile” /]
[EFQueryCache count=“1146” /]
[EpiCommand hashCode=“4039218143737099188” queryType=“SELECT,SELECT,SELECT” spid=“60” table="[Ice].[SysLock]"]
[parameters]
[parameter name=“p__linq__0” type=“String”][![CDATA[]]][/parameter]
[parameter name=“p__linq__1” type=“String”][![CDATA[DataAdm]]][/parameter]
[/parameters][![CDATA[
SELECT
CASE WHEN ( EXISTS (SELECT
1 AS [C1]
FROM [Ice].[SysLock] AS [Extent1]
WHERE ([Extent1].[Company] = @p__linq__0) AND ([Extent1].[SysFunction] = @p__linq__1)
)) THEN cast(1 as bit) ELSE cast(0 as bit) END AS [C1]
FROM ( SELECT 1 AS X ) AS [SingleRowTable1]
]]][/EpiCommand]
[DBStatement type=“Boolean” duration=“0.8822” rowCount=“1” hashCode=“4039218143737099188” dbContextId=“2272107c-6cec-4ad2-9732-5ec73f8dacc3”]
[stackTrace]
[stackFrame method=“TResult Epicor.Data.DBExpressionCompiler.InvokeSingle(Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TContext dataContext, Func2 getDataCacheKey, Func
2 compileQuery, Func3 executeQuery)" module="Epicor.System.dll" file="C:\_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs" line="311" /] [stackFrame method="TResult Epicor.Data.DBExpressionCompiler+<>c__DisplayClass34_0
4[TContext,TArg1,TArg2,TResult].<Compile>b__0(TContext context, TArg1 arg1, TArg2 arg2)” module=“Epicor.System.dll” file=“C:_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs” line=“1110” /]
[stackFrame method=“Void Ice.Manager.Security.LogOn(IceContext dataContext, String userID, Guid sessionType)” module=“Epicor.Ice.dll” file=“C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Manager\Security.cs” line=“504” /]
[stackFrame method=“Session Epicor.Hosting.CallContext.Create(Operation op)” module=“Epicor.Ice.dll” file=“C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Hosting\CallContext.cs” line=“155” /]
[stackFrame method=“IPrincipal Ice.Security.RestApi.AuthHelper.CheckAccess(String headerScheme, String headerValue, IEnumerable1 customHeaders)" module="Epicor.Ice.dll" file="C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Security\RestAuthHelper.cs" line="47" /] [stackFrame method="IPrincipal Epicor.RESTApi.Security.IceSecurityChecker.MakeAuth(IOwinRequest request)" module="Epicor.RESTApi.dll" file="C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.RESTApi\Security\CallAuth.cs" line="33" /] [stackFrame method="Task Epicor.RESTApi.ConfigureStartup+<>c__DisplayClass3_0.<ConfigureIceAuth>b__0(IOwinContext context, Func
1 next)” module=“Epicor.RESTApi.dll” file=“C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.RESTApi\Startup.cs” line=“116” /]
[stackFrame method=“Void Microsoft.Owin.Cors.CorsMiddleware+<Invoke>d__0.MoveNext()” module=“Microsoft.Owin.Cors.dll” file="" line=“0” /]
[stackFrame method=“Void System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start(TStateMachine& stateMachine)” module=“CommonLanguageRuntimeLibrary” file="" line=“0” /]
[stackFrame method=“Task Microsoft.Owin.Cors.CorsMiddleware.Invoke(IDictionary2 environment)" module="Microsoft.Owin.Cors.dll" file="" line="0" /] [stackFrame method="Void Microsoft.Owin.Mapping.MapWhenMiddleware+<Invoke>d__0.MoveNext()" module="Microsoft.Owin.dll" file="" line="0" /] [stackFrame method="Void System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start(TStateMachine& stateMachine)" module="CommonLanguageRuntimeLibrary" file="" line="0" /] [stackFrame method="Task Microsoft.Owin.Mapping.MapWhenMiddleware.Invoke(IDictionary
2 environment)” module=“Microsoft.Owin.dll” file="" line=“0” /]
[stackFrame method=“Void Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage+<RunApp>d__5.MoveNext()” module=“Microsoft.Owin.Host.SystemWeb.dll” file="" line=“0” /]
[stackFrame method=“Task Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage.RunApp(Func2 entryPoint, IDictionary
2 environment, TaskCompletionSource1 tcs, StageAsyncResult result)" module="Microsoft.Owin.Host.SystemWeb.dll" file="" line="0" /] [stackFrame method="IAsyncResult Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage.BeginEvent(Object sender, EventArgs e, AsyncCallback cb, Object extradata)" module="Microsoft.Owin.Host.SystemWeb.dll" file="" line="0" /] [stackFrame method="Void System.Web.HttpApplication+AsyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()" module="System.Web.dll" file="" line="0" /] [stackFrame method="Void System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)" module="System.Web.dll" file="" line="0" /] [stackFrame method="Exception System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)" module="System.Web.dll" file="" line="0" /] [stackFrame method="Void System.Web.HttpApplication+PipelineStepManager.ResumeSteps(Exception error)" module="System.Web.dll" file="" line="0" /] [stackFrame method="IAsyncResult System.Web.HttpApplication.BeginProcessRequestNotification(HttpContext context, AsyncCallback cb)" module="System.Web.dll" file="" line="0" /] [stackFrame method="RequestNotificationStatus System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context)" module="System.Web.dll" file="" line="0" /] [stackFrame method="Int32 System.Web.Hosting.PipelineRuntime.ProcessRequestNotificationHelper(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)" module="System.Web.dll" file="" line="0" /] [stackFrame method="Int32 System.Web.Hosting.PipelineRuntime.ProcessRequestNotification(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)" module="System.Web.dll" file="" line="0" /] [stackFrame method="Void System.Web.Hosting.UnsafeIISMethods.MgdIndicateCompletion(IntPtr pHandler, RequestNotificationStatus& notificationStatus)" module="System.Web.dll" file="" line="0" /] [stackFrame method="Void System.Web.Hosting.UnsafeIISMethods.MgdIndicateCompletion(IntPtr pHandler, RequestNotificationStatus& notificationStatus)" module="System.Web.dll" file="" line="0" /] [stackFrame method="Int32 System.Web.Hosting.PipelineRuntime.ProcessRequestNotificationHelper(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)" module="System.Web.dll" file="" line="0" /] [stackFrame method="Int32 System.Web.Hosting.PipelineRuntime.ProcessRequestNotification(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)" module="System.Web.dll" file="" line="0" /] [/stackTrace] [/DBStatement] [EFQueryCache count="1146" /] [DataContext msg="Enlisting in Transaction 91cd3799-de64-4984-8b7a-d0c957ca9120:465850, SPID:60" /] [EpiCommand hashCode="3820937654757427724" lockHints="UPDLOCK" queryType="SELECT" spid="60" table="[Ice].[SysUserFile]"] [parameters] [parameter name="p__linq__0" type="String"][![CDATA[username]]][/parameter] [/parameters][![CDATA[ SELECT TOP (1) [Extent1].[UserID] AS [UserID], [Extent1].[Password] AS [Password], [Extent1].[Name] AS [Name], [Extent1].[Address1] AS [Address1], [Extent1].[Address2] AS [Address2], [Extent1].[City] AS [City], [Extent1].[State] AS [State], [Extent1].[ZIP] AS [ZIP], [Extent1].[Country] AS [Country], [Extent1].[OfficePhone] AS [OfficePhone], [Extent1].[Phone] AS [Phone], [Extent1].[EMailAddress] AS [EMailAddress], [Extent1].[UserDisabled] AS [UserDisabled], [Extent1].[SecurityMgr] AS [SecurityMgr], [Extent1].[CanChangeSaveSettings] AS [CanChangeSaveSettings], [Extent1].[SaveSettings] AS [SaveSettings], [Extent1].[CurComp] AS [CurComp], [Extent1].[PwdLastChanged] AS [PwdLastChanged], [Extent1].[PwdExpiresDays] AS [PwdExpiresDays], [Extent1].[PwdExpires] AS [PwdExpires], [Extent1].[PwdGrace] AS [PwdGrace], [Extent1].[GroupList] AS [GroupList], [Extent1].[CompList] AS [CompList], [Extent1].[ViewFavoriteBar] AS [ViewFavoriteBar], [Extent1].[ViewMenuTree] AS [ViewMenuTree], [Extent1].[ViewStatusBar] AS [ViewStatusBar], [Extent1].[WinX] AS [WinX], [Extent1].[WinY] AS [WinY], [Extent1].[FavBarWidth] AS [FavBarWidth], [Extent1].[MenuTreeWidth] AS [MenuTreeWidth], [Extent1].[CurFolderSeq] AS [CurFolderSeq], [Extent1].[CurMenuID] AS [CurMenuID], [Extent1].[WinWidth] AS [WinWidth], [Extent1].[WinHeight] AS [WinHeight], [Extent1].[DispTips] AS [DispTips], [Extent1].[CanChangePassword] AS [CanChangePassword], [Extent1].[LangNameID] AS [LangNameID], [Extent1].[LastGraphType] AS [LastGraphType], [Extent1].[UseInternalWebBrowser] AS [UseInternalWebBrowser], [Extent1].[AllowMultipleSessions] AS [AllowMultipleSessions], [Extent1].[WebUser] AS [WebUser], [Extent1].[ListViewMode] AS [ListViewMode], [Extent1].[CanMaintainFavQueries] AS [CanMaintainFavQueries], [Extent1].[CanMaintainFavURLs] AS [CanMaintainFavURLs], [Extent1].[CanMaintainFavPrograms] AS [CanMaintainFavPrograms], [Extent1].[CanCustomize] AS [CanCustomize], [Extent1].[ViewTreeOnly] AS [ViewTreeOnly], [Extent1].[Timeout] AS [Timeout], [Extent1].[CanPersonalize] AS [CanPersonalize], [Extent1].[CanTranslate] AS [CanTranslate], [Extent1].[CanEditCompAnnotations] AS [CanEditCompAnnotations], [Extent1].[CanEditUserAnnotations] AS [CanEditUserAnnotations], [Extent1].[CanEditHelpLinks] AS [CanEditHelpLinks], [Extent1].[AutoStartMonitor] AS [AutoStartMonitor], [Extent1].[MonitorPollingInterval] AS [MonitorPollingInterval], [Extent1].[FormOpenMode] AS [FormOpenMode], [Extent1].[EntConType] AS [EntConType], [Extent1].[DashboardDeveloper] AS [DashboardDeveloper], [Extent1].[CanDesignQSearch] AS [CanDesignQSearch], [Extent1].[RequireSso] AS [RequireSso], [Extent1].[ViewStatusPanelUserID] AS [ViewStatusPanelUserID], [Extent1].[ViewStatusPanelLanguage] AS [ViewStatusPanelLanguage], [Extent1].[ViewStatusPanelCompany] AS [ViewStatusPanelCompany], [Extent1].[ViewStatusPanelPlant] AS [ViewStatusPanelPlant], [Extent1].[ViewStatusPanelServer] AS [ViewStatusPanelServer], [Extent1].[ViewStatusPanelWorkstationID] AS [ViewStatusPanelWorkstationID], [Extent1].[ServerNum] AS [ServerNum], [Extent1].[DomainName] AS [DomainName], [Extent1].[BPMAdvancedUser] AS [BPMAdvancedUser], [Extent1].[MaxGroupsFavorites] AS [MaxGroupsFavorites], [Extent1].[MaxGroupsSystemMenu] AS [MaxGroupsSystemMenu], [Extent1].[OSUserID] AS [OSUserID], [Extent1].[CanTheme] AS [CanTheme], [Extent1].[FormatCulture] AS [FormatCulture], [Extent1].[CanUseEntSearch] AS [CanUseEntSearch], [Extent1].[CanAccEpiEverywhere] AS [CanAccEpiEverywhere], [Extent1].[CanAcessMobile] AS [CanAcessMobile], [Extent1].[StartMenuClient] AS [StartMenuClient], [Extent1].[StartMenuEWA] AS [StartMenuEWA], [Extent1].[StartMenuMobile] AS [StartMenuMobile], [Extent1].[AdvBAQRights] AS [AdvBAQRights], [Extent1].[SecurityAccessOnly] AS [SecurityAccessOnly], [Extent1].[SolutionMgrCreate] AS [SolutionMgrCreate], [Extent1].[SolutionMgrInstall] AS [SolutionMgrInstall], [Extent1].[EntSearchURL] AS [EntSearchURL], [Extent1].[CanMaintQuickSearch] AS [CanMaintQuickSearch], [Extent1].[UseDefaultEntSearch] AS [UseDefaultEntSearch], [Extent1].[UserAccessOnly] AS [UserAccessOnly], [Extent1].[GlbCompSM] AS [GlbCompSM], [Extent1].[BAQXCompany] AS [BAQXCompany], [Extent1].[LastLogOnAttempt] AS [LastLogOnAttempt], [Extent1].[CanImpersonate] AS [CanImpersonate], [Extent1].[ViewStatusPanelSolutionID] AS [ViewStatusPanelSolutionID], [Extent1].[CanMaintPredictiveSearch] AS [CanMaintPredictiveSearch], [Extent1].[ViewESEPanel] AS [ViewESEPanel], [Extent1].[ESEUserID] AS [ESEUserID], [Extent1].[ESEPassword] AS [ESEPassword], [Extent1].[ThemeID] AS [ThemeID], [Extent1].[DisableTheming] AS [DisableTheming], [Extent1].[SysRevID] AS [SysRevID], [Extent1].[SysRowID] AS [SysRowID], [Extent1].[CanPublishLayout] AS [CanPublishLayout], [Extent1].[DefaultLayoutID] AS [DefaultLayoutID], [Extent1].[CanViewDocStar] AS [CanViewDocStar], [Extent1].[PwdChangeRequestOn] AS [PwdChangeRequestOn], [Extent1].[ExternalIdentity] AS [ExternalIdentity] FROM [Ice].[SysUserFile] AS [Extent1] WITH (UPDLOCK) WHERE [Extent1].[UserID] = @p__linq__0 ]]][/EpiCommand] [DBStatement type="SysUserFile" duration="4.7816" rowCount="1" hashCode="3820937654757427724" dbContextId="2272107c-6cec-4ad2-9732-5ec73f8dacc3"] [stackTrace] [stackFrame method="TResult Epicor.Data.DBExpressionCompiler.InvokeSingle(Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TContext dataContext, Func
2 getDataCacheKey, Func2 compileQuery, Func
3 executeQuery)” module=“Epicor.System.dll” file=“C:_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs” line=“0” /]
[stackFrame method=“TResult Epicor.Data.DBExpressionCompiler+<>c__DisplayClass33_03[TContext,TArg1,TResult].<Compile>b__0(TContext context, TArg1 arg1)" module="Epicor.System.dll" file="C:\_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs" line="1082" /] [stackFrame method="Void Ice.Manager.Security.LogOn(IceContext dataContext, String userID, Guid sessionType)" module="Epicor.Ice.dll" file="C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Manager\Security.cs" line="514" /] [stackFrame method="Session Epicor.Hosting.CallContext.Create(Operation op)" module="Epicor.Ice.dll" file="C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Hosting\CallContext.cs" line="155" /] [stackFrame method="IPrincipal Ice.Security.RestApi.AuthHelper.CheckAccess(String headerScheme, String headerValue, IEnumerable
1 customHeaders)” module=“Epicor.Ice.dll” file=“C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Security\RestAuthHelper.cs” line=“47” /]
[stackFrame method=“IPrincipal Epicor.RESTApi.Security.IceSecurityChecker.MakeAuth(IOwinRequest request)” module=“Epicor.RESTApi.dll” file=“C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.RESTApi\Security\CallAuth.cs” line=“33” /]
[stackFrame method=“Task Epicor.RESTApi.ConfigureStartup+<>c__DisplayClass3_0.<ConfigureIceAuth>b__0(IOwinContext context, Func1 next)" module="Epicor.RESTApi.dll" file="C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.RESTApi\Startup.cs" line="116" /] [stackFrame method="Void Microsoft.Owin.Cors.CorsMiddleware+<Invoke>d__0.MoveNext()" module="Microsoft.Owin.Cors.dll" file="" line="0" /] [stackFrame method="Void System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start(TStateMachine& stateMachine)" module="CommonLanguageRuntimeLibrary" file="" line="0" /] [stackFrame method="Task Microsoft.Owin.Cors.CorsMiddleware.Invoke(IDictionary
2 environment)” module=“Microsoft.Owin.Cors.dll” file="" line=“0” /]
[stackFrame method=“Void Microsoft.Owin.Mapping.MapWhenMiddleware+<Invoke>d__0.MoveNext()” module=“Microsoft.Owin.dll” file="" line=“0” /]
[stackFrame method=“Task Microsoft.Owin.Mapping.MapWhenMiddleware.Invoke(IDictionary2 environment)" module="Microsoft.Owin.dll" file="" line="0" /] [stackFrame method="Void Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage+<RunApp>d__5.MoveNext()" module="Microsoft.Owin.Host.SystemWeb.dll" file="" line="0" /] [stackFrame method="Void System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start(TStateMachine& stateMachine)" module="CommonLanguageRuntimeLibrary" file="" line="0" /] [stackFrame method="Task Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage.RunApp(Func
2 entryPoint, IDictionary2 environment, TaskCompletionSource
1 tcs, StageAsyncResult result)” module=“Microsoft.Owin.Host.SystemWeb.dll” file="" line=“0” /]
[stackFrame method=“IAsyncResult Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage.BeginEvent(Object sender, EventArgs e, AsyncCallback cb, Object extradata)” module=“Microsoft.Owin.Host.SystemWeb.dll” file="" line=“0” /]
[stackFrame method=“Void System.Web.HttpApplication+AsyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()” module=“System.Web.dll” file="" line=“0” /]
[stackFrame method=“Void System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)” module=“System.Web.dll” file="" line=“0” /]
[stackFrame method=“Exception System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)” module=“System.Web.dll” file="" line=“0” /]
[stackFrame method=“Void System.Web.HttpApplication+PipelineStepManager.ResumeSteps(Exception error)” module=“System.Web.dll” file="" line=“0” /]
[stackFrame method=“IAsyncResult System.Web.HttpApplication.BeginProcessRequestNotification(HttpContext context, AsyncCallback cb)” module=“System.Web.dll” file="" line=“0” /]
[stackFrame method=“RequestNotificationStatus System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context)” module=“System.Web.dll” file="" line=“0” /]
[stackFrame method=“Int32 System.Web.Hosting.PipelineRuntime.ProcessRequestNotificationHelper(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)” module=“System.Web.dll” file="" line=“0” /]
[stackFrame method=“Int32 System.Web.Hosting.PipelineRuntime.ProcessRequestNotification(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)” module=“System.Web.dll” file="" line=“0” /]
[stackFrame method=“Void System.Web.Hosting.UnsafeIISMethods.MgdIndicateCompletion(IntPtr pHandler, RequestNotificationStatus& notificationStatus)” module=“System.Web.dll” file="" line=“0” /]
[/stackTrace]
[/DBStatement]
[EpiCommand queryType=“UPDATE,SELECT” spid=“60” table="[Ice].[SysUserFile],[Ice].[SysUserFile]"]
[parameters]
[parameter name="@0" type=“DateTime2”][![CDATA[8/15/2018 7:17:36 AM]]][/parameter]
[parameter name="@1" type=“Guid”][![CDATA[6867ca17-479c-49d7-8874-70d9cbb62274]]][/parameter]
UPDATE [Ice].[SysUserFile]
SET [LastLogOnAttempt] = @0
WHERE ([SysRowID] = @1)
SELECT [SysRevID]
WHERE @@ROWCOUNT ] 0 AND [SysRowID] = @1
]]][/EpiCommand]
[Trigger msg=“Enabling SysUserFile” /]
[EpiConnection oper=“Disposed” spid=“60” /]
[SessionSetting msg=“SessionID changed from ‘00000000-0000-0000-0000-000000000000’ to ‘c26c8243-46b2-4505-bf8e-731c06ca88d8’” /]
[Session msg=“New ErpSession created: c26c8243-46b2-4505-bf8e-731c06ca88d8 for User: in Company: " /]
[SessionSetting msg=“SessionType changed from ‘00000000-0000-0000-0000-000000000000’ to ‘00000003-b615-4300-957b-34956697f040’” /]
[SessionSetting msg=“UserID changed from ‘null’ to ‘username’” /]
[SessionSetting msg=“Timeout changed from ‘0’ to ‘900’” /]
[SessionSetting msg=“CompanyID changed from ‘null’ to ‘COMPANYNAME’” /]
[Session msg=“Changing from Company: to new Company:COMPANYNAME for Session:c26c8243-46b2-4505-bf8e-731c06ca88d8” /]
[SessionSetting msg=“CompanyName changed from ‘null’ to ‘TEST 20180802’” /]
[SessionSetting msg=“PlantID changed from ‘null’ to ‘MfgSys’” /]
[SessionSetting msg=“InstallationID changed from ‘00000000-0000-0000-0000-000000000000’ to ‘f162fb27-07a2-4a85-a0da-e739a2fe683f’” /]
[SessionSetting msg=“SolutionID changed from ‘null’ to ‘’” /]
[SessionSetting msg=“CountryCode changed from ‘null’ to ‘US’” /]
[SessionSetting msg=“CountryGroupCode changed from ‘null’ to ‘’” /]
[Session msg=“Changing from Company:COMPANYNAME to new Company:COMPANYNAME for Session:c26c8243-46b2-4505-bf8e-731c06ca88d8” /]
[SessionSetting msg=“LastAccessed changed from ‘1/1/0001 12:00:00 AM’ to ‘8/15/2018 2:17:00 PM’” /]
[Session msg=“Refreshing last accessed time on SessionID: c26c8243-46b2-4505-bf8e-731c06ca88d8. LastAccessed: 8/15/2018 2:17:00 PM” /]
[SessionSetting msg=“LicenseExpirationTime changed from ‘1/1/0001 12:00:00 AM’ to ‘8/15/2018 2:32:00 PM’” /]
[SessionSetting msg=“FormatCultureName changed from ‘null’ to ‘en-US’” /]
[DataContext msg=“New DataContext ID:35560ef4-c28b-4ae6-9732-4192e4dbba3e created on SPID:” /]
[ContextBound name=“Ice.Services.BO.DynamicQuerySvcFacade” contextid=“35560ef4-c28b-4ae6-9732-4192e4dbba3e” defaultcontext=“False” /]
[ContextBound name=“Ice.Services.BO.DynamicQuerySvc” contextid=“35560ef4-c28b-4ae6-9732-4192e4dbba3e” defaultcontext=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.0011” root=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.0378” root=“False” /]
[ContextBound name=“Ice.Services.BO.BAQDesignerSvcFacade” contextid=“35560ef4-c28b-4ae6-9732-4192e4dbba3e” defaultcontext=“False” /]
[ContextBound name=“Ice.Services.BO.BAQDesignerSvc” contextid=“35560ef4-c28b-4ae6-9732-4192e4dbba3e” defaultcontext=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.0275” root=“False” /]
[Sproc name=”[Ice]._ZFW_BAQDesigner_GetByID" duration=“5.2865” /]
[TablesetEvent tsName=“BAQDesignerTableset” method=“AfterGetRows” duration=“2949.3801000000003” /]
[RowCount tableset=“BAQDesignerTableset” count=“447” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.0015” root=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.0145” root=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.0007” root=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.0122” root=“False” /]
[Sproc name="[Ice]._ZFW_BAQDesigner_GetByID" duration=“10.7445” /]
[RowEvent table=“QueryFieldDesigner”
method=“AfterGetRows” rows=“72” duration=“0.0114” /]
[TablesetEvent tsName=“BAQDesignerTableset” method=“AfterGetRows” duration=“2737.0253000000002” /]
[DataContext msg=“New DataContext ID:824597df-1e44-4be1-85af-8cbc5f722a76 created on SPID:” /]
[ContextBound name=“Ice.Services.BO.DynamicQuerySvcFacade” contextid=“824597df-1e44-4be1-85af-8cbc5f722a76” defaultcontext=“False” /]
[ContextBound name=“Ice.Services.BO.DynamicQuerySvc” contextid=“824597df-1e44-4be1-85af-8cbc5f722a76” defaultcontext=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.0039000000000000003” root=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.076800000000000007” root=“True” /]
[ContextBound name=“Ice.Services.BO.BAQDesignerSvcFacade” contextid=“824597df-1e44-4be1-85af-8cbc5f722a76” defaultcontext=“False” /]
[ContextBound name=“Ice.Services.BO.BAQDesignerSvc” contextid=“824597df-1e44-4be1-85af-8cbc5f722a76” defaultcontext=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.0023” root=“False” /]
[Trace uri=“trace://ice/fw/perf/Initialize” duration=“0.061000000000000006” root=“False” /]
[Sproc name="[Ice]._ZFW_BAQDesigner_GetByID" duration=“12.9473” /]
[TablesetEvent tsName=“BAQDesignerTableset” method=“AfterGetRows” duration=“2790.9251” /]
[BAQ QueryID=“BAQQueryName” /]
[BAQ Company=“COMPANYNAME” /]
[DataContext msg=“New DataContext ID:bf055cb1-e619-4ef1-8595-8d100f80d00f created on SPID:” /]
[EpiConnection oper=“Opened” spid=“164” /]
[EpiConnection oper=“Disposed” spid=“164” /]
[DataContext msg=“New DataContext ID:6385a620-5b6a-45b3-bf48-d7b1ddeeee6a created on SPID:” /]
[DataContext msg=“New DataContext ID:4f664f39-2366-4216-8f25-3ad14f7969f3 created on SPID:” /]
[EpiConnection oper=“Opened” spid=“163” /]
[EpiConnection oper=“Disposed” spid=“163” /]
[DataContext msg=“New DataContext ID:566e4330-383b-4531-95d5-d876293dece0 created on SPID:” /]
[DataContext msg=“New DataContext ID:f9a4b77a-da09-44ab-9211-ac640cc8819b created on SPID:” /]
[DataContext msg=“New DataContext ID:d07f178f-5fe0-4e4a-8388-0b794798cb45 created on SPID:” /]
[DataContext msg=“New DataContext ID:0c3529b1-e14d-4f73-b179-8d7d9f2d497d created on SPID:” /]
[DataContext msg=“New DataContext ID:ac95d075-2f9c-4e43-96e3-038994d84f18 created on SPID:” /]
[DataContext msg=“New DataContext ID:a2ca8e35-844d-44f4-8be5-5daadcaa473b created on SPID:” /]
[DataContext msg=“New DataContext ID:dc8e352d-d95c-4ad5-8560-93cf4bf858c4 created on SPID:” /]
[DataContext msg=“New DataContext ID:b2420b53-a905-4977-9d05-5fc0e4d26a53 created on SPID:” /]
[BAQ SQLExecTime=“111.3852” /]
[BAQ DataFetchTime=“0.4277” /]
[BAQ TotalTime=“155.2636” /]
[BAQ TotalRows=“0” /]
[Session msg=“Skipping session save, no updates: c26c8243-46b2-4505-bf8e-731c06ca88d8” /]
[Expression hc=“3820937654757427724”][![CDATA[(ctx, userID_ex) =] Queryable.FirstOrDefault(Queryable.Where(
WithExtension.With(
ctx.SysUserFile,
UpdLock
row =] row.UserID == userID_ex
))]]][/Expression]
[Expression hc=“4039218143737099188”][![CDATA[(ctx, company_ex, sysFunction_ex) =] Queryable.Any(Queryable.Where(
ctx.SysLock,
row =] row.Company == company_ex && row.SysFunction == sysFunction_ex
))]]][/Expression]
[/Op]
