When I add the Log Message widget into my function I’m getting the following error:
error CS0122: 'FunctionBase<ErpContext, FunctionInput, FunctionOutput>.Log(BusinessObjectMessageType, string)' is inaccessible due to its protection level
I’m assuming this is a bug and there’s nothing I can do about it (2022.2.9)?
Doug as it turns out someone has. Perusing hte inbound bug list I just rejected yours. Took a bit but I tracked down PRB0255092 reported earlier this year. It has been fixed in 2023.1
Is it any workaround for it? How does the code of this widget looks like? I mean if someone with version 2023.1 could check it will be really nice Just add the test function with the widget and then dump sources and see how the code looks like.
Lately I found that it is saving information and it can be read only in event viewer on app server. It’s not saving it to the log file at all. Is it normal?
