Lon,
Thank you for the information. I am glad to hear others are using
Access to provide reports from Progress as well.
I have used Access for reports also (8 level BOM and Job Costs per
projects with POs and delivery dates).
Thanks again.
Dave Kwiatkowski
Barber-Nichols Inc.
Thanks again.
Dave Kwiatkowski
Barber-Nichols Inc.
--- In vantage@yahoogroups.com, <lonwiksell@...> wrote:
> DBF files are the old dbase II, III, IV format. These are files are
> predefined by Vantage. When you run a Crystal Report (at least it
works
> this way in 6.1, I don't know 8.0) the data is dowloaded from
Vantage to
> the DBF files on your C drive. If you want data that is not in the
DBF
> files you have to add a subreport that uses ODBC to the Vantage
tables
> to get that data. This can be slow and frustrating. We modified
the
> Crystal Reports so much that our invoicing report had to have 8
> subreports and took forever to print (17 minutes to be exact). We
now
> use Access through ODBC to get the data from Vantage. We can print
an
> invoice in 1 second.
> Lon A. Wiksell
> ROM Corp
> 913-318-8000
Behalf
> Of davek2127
> Sent: Thursday, April 05, 2007 9:55 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Local User *.DBF Files
> What is the purpose of the local user *.dbf files?
> Can these files be created through a write procedure from Progress?
> I have seen that several of our Crystal reports use a combination
of
> ODBC data sources and local datasources (*.dbf files residing on
local
> C drives).
> Any help here would be greatly appreciated? Even pointing me
> to a description of the use of these files in Vantage
> documentation.
> Dave Kwiatkowski
> Barber-Nichols Inc.
