Hi Folks. I’m having trouble trying to write updated records to the UD105A table. I don’t see the problem, as I have written to other tables in this fashion numerous times without incident. I tried to do it using Linq, and then tried to update using SvcContract. The two code snippets are below. If anyone sees something that I’m missing and would point it out to me, I would be appreciative. Thanks.
Version 1:
foreach (var _UD105a_row in (from u5 in Db.UD105
join u5a in Db.UD105A
on new { u5.Company, u5.Key1, u5.Key2, u5.Key3, u5.Key4, u5.Key5 }
equals new { u5a.Company, u5a.Key1, u5a.Key2, u5a.Key3, u5a.Key4, u5a.Key5 }
where u5.Company == Session.CompanyID
&& u5.Key5 == strShipmentID
&& (u5.ShortChar05 == strShipVia2 || strShipVia2 == "" || strShipVia2 == "ALL")
&& (u5a.ShortChar07 == "" || strOption.ToUpper() == "FORCE")
select u5a))
_UD105a = _UD105a_row;
fMsg("fixUD105TrackingNum ... {" + _UD105a.SysRowID.ToString().ToUpper() + "} changed from \"" + _UD105a.Character07 + "\" to \"" +
strTrackingNum + "\".");
_UD105a.Character07 = strTrackingNum;
In Version 1, you want to wrap your Db hard updates like the following (and only use them as a last resort where the services don’t provide a mechanism to do what you want):
using (var txn = IceContext.CreateDefaultTransactionScope())
// your code here
Db.Validate();
txn.Complete();
For Version 2, I only glanced for about 10 seconds… have you tried removing your suppressed catch to see if you’re actually successfully getting data there?
In both instances, I am getting data. It’s just not writing the updates to the table. I’ve used both versions in other scenarios and they update without incident.
This works as long as data comes back. What field name are you passing into strOption? Seems odd to take a UD column to upper case or a regular column name. Something like this below works
You say you are getting data back, so I assume you have a log or message (fMsg) that is firing inside of the loop to verify this. If this is the case, are you confident that strTrackingNum actually has a non null value?
v1 should work fine, depending on where you are calling it… If its in a POST then you might want to do like @josephmoeller said use a TransactionScope - also you might have to refresh the DataSet, if you are expecting the UI to change after a POST.
Also Epicor might by default do a LockHint.NoLock (readonly) so ask for a Lock
foreach (var _UD105a_row in (from u5 in Db.UD105.With(LockHint.UpdLock)
join u5a in Db.UD105A.With(LockHint.UpdLock)
select u5a))
Example:
using (var txScope = IceDataContext.CreateDefaultTransactionScope())
var PartPlants =
from pp in Db.PartPlant.With(LockHint.UpdLock)
where
pp.Company == Session.CompanyID
&& pp.Number01 == 0
select pp;
foreach (var partPlantRow in PartPlants)
partPlantRow.Number01 = 1;
Db.Validate();
txScope.Complete();
One of the things we see a lot is locks blocking folks at scale. One of the patterns we use a lot internally is:
Collection read with no lock
Make decisions on whether to update elements in the collection
Iterate through the trimmed collection
Read with lock //minimizing lock scope
Update
Commit
It’s amazing how performance and lock contention (e.g. - scale) is improved with this pattern. Especially when that area of should I do something may call out into many libs and their dependent libs.
@Bart_Elia would one ever use Db.IsLocked in a BPM? Never found a use case for it.
// If the record exists and is locked by someone else, the function returns true.
// In all other cases it returns false, but will lock the record for you in the process.
if (Db.IsLocked(POHeader)) {
// do work
You probably have never written a BPM with 13K lines in it
(Upgrade Services (aka Cirrus) allows for some interesting analysis of BPMs in the wild.)
In general you probably don’t need it. If you start creating an entire service in a BPM though and get some intense biz logic, it’s nice to have in the toolbox.
I found the problem. It wasn’t in this routine, it was in a section further down that was throwing an exception message instead of an information message.
