Linking operations
Hi Guys,
I’m sure this is an easy fix but I can’t seem to find it. I want my Op25 to start after my Op10. Right now based on scheduling factors it is directly following my Op21 and I don’t know how to link the two. It is tedious when I am re-scheduling and I have to go into each scheduling board and move the operations around manually.
In the example below I want Op25 to start on Jan 25th, not on Jan 14th right after Op21.
You can only set an operation’s relationship with its immediate predecessor, so in this case I would set Ops 10, 20, and 21 to Finish-Finish scheduling relationships and Op 25 to Start-Finish. That would have Ops 10, 20, and 21 all ending at the same time and Op 25 starting after they all finish.
