Thought I'd post the answer in case someone else is looking for the same info. The GL control codes for PREmpMas are in the EntityGLC table. Link company to company and EmpID to Key1. Set criteria to the RelatedToFile to = PREmpMas.
EntityGLC holds GL control codes to a number of tables. I've found the values for RelatedToFile and Keys1-6 are generally the same as the links given in the Epicor spreadsheet with TranGLC links (spreadsheet can be found in the files section). The only difference I've found is the EntityGLC link for APInvHed includes Key3=GroupID; the TranGLC link for APInvHed doesn't use Key3.
Sue
Sue
