Limiting UD Combo Box to My Specific UserCodeType
hey all, i tried following along with these two posts (One / Two) as well as reading through some E10 conversations but im coming up short when i try anything new.
i successfully added a new combo box to Part. I created my UD field and had the database regenerated and refreshed. I then made sure all of my combo box fields were following along with the linked threads above…the combo box works nicely but its pulling ALL of my user codes and not just the one specified in my “Filters Param” section. I tried adding single and double quotes to the filter params but nothing changed. I also added my usercode type to the advanced>User CodeId field but that pops up a “Parameter whereClauseUDCodeType is not found in the input object” error.
any help is greatly appreciated, thanks!
1
2
Is your user code type actually MyUserCodeTypeID?
If it is, it should be single quotes.
In your Filters Params, use CodeTypeParam instead of CodeTypeID:
You will still use MyUserCodeTypeID
