Has anyone ever seen this happen before and know how to fix it? I worked on a dashboard and had it set up the way I wanted it, then deployed it, and added it to the menu. After closing and re-opening Epicor, it now has a messed up view when using Dashboard Maintenance, but the menu dashboard loads fine. I can’t make any additional changes to it.
I’m interested in what this post yields. I had this with a dashboard too and I never understood it. I think I had to copy the dashboard and then start from there.
I’ve had this happen on several in the past and I’ve always had to start from scratch, so I’m hoping someone will have a solution that is better than that.
I have tried resetting layouts to default and that didn’t fix it.
I tried removing the updatable status from the grid view and it then gave me this error:
Application Error
Exception caught in: Ice.UI.Dashboard
Error Detail
Message: Object reference not set to an instance of an object.
Program: Ice.UI.Dashboard.dll
Method: DashboardView_ViewChanged
Client Stack Trace
at Ice.UI.Dashboard.DashboardDockManager.DashboardView_ViewChanged(ViewEventArgs args)
at Ice.UI.Dashboard.ViewChanged.Invoke(ViewEventArgs args)
at Ice.UI.Dashboard.DashboardView.OnViewPropertiesChanged()
at Ice.UI.Dashboard.DashboardViewManager.ApplyViewProperties(ViewPropertiesPanel panel, DashboardView View)
