Thanks. Your information as well as other e-mail solutions from the group is
very helpful.
Best Regards,
Herby Dallard
Information Technology Engineer
Endicott Research Group
hdallard@...
607-754-9187 ext. 3078
www.ergpower.com
_____
bw2868bond
Sent: Monday, August 24, 2009 11:14 AM
Subject: [Vantage] Re: LaunchForm with VB.Net in Customization
I guess it depends on the requirements of what you are trying to launch.
Launching Sales Order Ack (Crystal Report) Form from within Sales Order
Entry:
dim num as Integer = Integer.Parse(oTrans.CurrentOrderNum)
If (num > 0) Then
Try
Dim options2 As New LaunchFormOptions()
options2.SuppressFormSearch = True
options2.ValueIn = num.ToString
ProcessCaller.LaunchForm(oTrans, "Epicor.Mfg.UIRpt.SalesOrderAck", options2)
Catch
End Try
End If
Launching another Vantage (Window) Form:
Dim myNewForm As Object = ProcessCaller.LaunchForm(oTrans, "Menu ID")
Where Menu ID is, for example, "SUMT2000" (Menu Maintenance)
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
"herbydallard" <hdallard@...> wrote:
very helpful.
Best Regards,
Herby Dallard
hdallard@...
www.ergpower.com
_____
bw2868bond
Entry:
If (num > 0) Then
Try
Catch
End Try
End If
>launchform? VB.Net Example:
> Does anyone have successful code using the UI Object Process Caller method
>[Non-text portions of this message have been removed]
> Dim [varName] As Object = ProcessCaller.LaunchForm(Sender, AssemblyName)
> What sample arguments would replace Sender and Assemblyname?
> Thanks.
> Best Regards,
> Herby Dallard
> IT Engineer
