Last part of Conversion to 9.05.700C has error, cvim0219.p any input
Hello Group;
During conversion from 8.03.410 -> 9.05.700C using DUU tool, the last part of the conversion process once opening 9.05 with Admin Tool and conversions.
The last conversion run is "cv/cvim0219.p" which is "Assign COSTID to PartTran Records" gives following error:
"**FIND FIRST/LAST failed for table Plant (565)"
Holding the Enter key to pass all of the OK clicks, and the conversion finishes. Reviewing the list of conversions, it is the last one and is marked as "Completed" with today's date so I believe it finished.
It kind of makes sense because I don't believe there was a Plant table in 8.03?
Any input appreciated if you have seen this or know if it is a critical thing. Epicor opens just fine after this.
Regards,
George Hicks
