Epicor version 10.1.400.18. I cannot get this adapter to behave. I am trying to update our 9.05 customization. The customization is called Holiday Entry and is built on top of the Time and Expense Entry form. It allows the user to select a date, input the number of holiday hours, select multiple employees, and press a button to apply these hours to each employee. I was wondering if anyone else is having trouble with this adapter. The easiest way to tell if the problem exists is to open the labor adapter with the BL Tester and simply select the GetNewLaborDtlWithHdr method. It immediately pops up an error stating āUnhandled exception has occurred in a component in your application. Unknown parameter type: RuntimeParameterInfo for parameter ipClockInDate.ā When you are selecting the method in the BLTester, the Signature shows question marks in the parameters. Iāve never seen this before. Iām thinking they were working on this DLL and āforgotā to update it?
Iām waiting on a trace from our plant to look into this further but Iāll bet Iām going to see LaborImpl adapter methods and Iām not sure what the Impl is supposed to mean to me.
Thanks Jose! That is getting me somewhere. It led me to take a close look at the definition of the parameters for the GetNewDtlWithHdr method. Seems they are using a System.Nullableā1 parameter type for DateTime. I have not seen that before. Must be something new with writing straight to SQL instead of Progress writing to SQL.
Which led me to another post which showed the System.Nullable type.
I had the Adapter.ClearData() function in there and remarked it outā¦.for some reason. Iāll put it back in there and move the load and dispose outside the loop and see if it works.
Error: BC31429 - line 298 (1028) - āclearDataā is ambiguous because multiple kinds of members with this name exist in class āIce.Lib.Framework.EpiBaseAdapterā.
