Labor Reporting Resource /Scheduling Resource not updating in Method
Has anyone else run into the issue of Labor Reporting Resource and Scheduling Resource not updating when you change the Op Code through DMT?
I have tried other fields through DMT for the Bill Of Operations table including PrimaryResourceGrpID, ECOOpDt#ResourceGrpID, ECOOpDtl#ResourceID but none seem to work. I can’t use the mass replace group option either as I only want to do this for a subset of parts.
Does anyone know the field or table you would have to use?
Not sure if this applies in your case or if it is still a “thing”
but I seem to remember a DMT template once where I needed to add a description column in addition to the code column - related to combos and it wasn’t listed in the template builder.
Hi Bruce, I just ended up changing the related operation on the bom materials, deleted and readded the operation, and then reattached the materials to the new operation. Not the most efficient way but I couldn’t find the right field or table.
