We are implementing 10.2.200. This is our second month into the implementation. When we ran our scenario, we saw that there were no labor entries made. The burden entries were good. Labor rates are assigned to the resource group. We are confused.
The labor rate assigned to the resource group is not used by the system for actual labor. That value is assigned to the individual worker in the employee master file. The resource labor rate is used for the estimated labor value you see on the production detail report. Strange, but true.
Thatâs what EPICOR said. So, I input a rate and nothing happened. Am I supposed to add a GL CODE / TYPE?
Just to be sure Iâm following, you entered a rate in the employee file, the employee clocked in to a job, did some work, ended activity on the job and dollar value of the labor hours did not book to the job? Yes?
We posted the rate in the employee file after the job was closed. Thought it might go retroactive - but we were wrong. We will test further tomorrow with new activity. Still leaves the issue of why doesnât the system use the resource labor rate. The employee rate does not work for us.
I sent you some materials via email (TechRef guides). We do not have GL Controls on the employee, btw.
Employee labor rates do come from the employee record, while estimates come from the Resource.
We too want to use the Resource Group rate, so I went searching. Lots of folks asking the same, but no âeasy fixâ answers yet. I did reach out to one person and Iâll post here when I hear back.
WellâŚit is what it isâŚthe employee rate is how the basic system works. It was designed that way and has been functioning since version 5.0 that I know of. If you have fairly accurate production standards, labor back flushing might be something to consider, but if and only if your production standards are good.
HTH
Thanks Mike - not very happy
Thank you Claudia. We may need a customization.
Can I ask a business question? Why does the labor rate for your guys use case need to change for different resources? From what I understand, thatâs what burden rate is designed to do. Why do you need it on the labor rate?
Burden is manufacturing overhead. Labor should not be a part of the burden rate. I want to use separate rates to determine what my labor and overhead variances are. If I combine the rates, I wonât be able to see the separate issues. If the system has reporting that helps me identify labor variances, then I am open to that. But, we donât know enough yet. EPICOR consulting has not provided any options. Weâll see on Monday when the consultant arrives.
But why doesnât the labor rate follow the employee? I donât understand how that rate can change because the are working in a different area.
Our machines have a crew of 2 or more. We have to blend the rates. We have different rates for operators and helpers. In addition, we have built in overtime. This blend is optimal for us. Employees sometimes move around but that is difficult to track. So, the machine rate for labor works best for us.
The resource grp rate is what is used when you do a cost roll on a mfg part. So basically, itâs an estimated labor cost of manufacturing the part.
For example:
*if the resource grp rate = $10/hr and it takes 2 hrs estimated in the method master (routing) file to finish the job, then the partâs labor portion is costed as $20 ($10/hr x 2 hrs)
- When you go and manufacture that part and the employee reports time against that part on a job, then the employee rate is used to calculate actual labor cost (Employee Rate x Actual hrs = Actual labor cost). So, if the employee rate was $11/hr and it took 2.50 hrs, then the actual labor cost would be = $27.50 ($11/hr x 2.50 hrs). The difference between the actual and estimated cost would be labor variance.
So you arenât having employees actually clock into a job, you are essentially âclocking in a machineâ instead of an employee. Does that sound correct?
Would it be a better solution for you to make âemployeesâ in the system that are actually machines, and use those IDâs for employees to clock into the job? Then the machine could have the labor rate you want.
(FWIW, I donât agree with this method, I would rather have each employee clock into the operation so I know what each is doing, but I do know that can be difficult to impossible to accomplish because of the amount of transactions required)
Ok - I am with you. Next question - when setting up the employee in emp maint, do I need to use a gl control / type to capture the applied labor account?
Do not quote me on this (Iâm not great with GL accounts), but I think there is a hierarchy somewhere for what GL account itâs applied to. We do not have employees with a GL control, so that means you donât need them, as long as they are all going to the same place. I think you set up a control if you need something other than what you have set up as the default. In your case, it might not be a bad idea, but it all depends on what accounting wants to seeâŚ
I am the Controller - I want to see detail⌠Just have to figure out how.
I agree with Brandon - no GL controls on my employee records either.
However, I disagree with generic employee logins - you lose the auditability that way - if you care to have it. If not, then generic employee logins with the proper labor rate would work just fine without any special/custom work being done.
Remember, You can have more than one person clocking into an operation at the same time. So if you have a crew of 2 they can both be clocked into it. This would capture the labor rate for both people.
I would have to do some testing to what that does with the burden in that case. The system is set up for 1 person to run multiple machines, or just run 1 machine at a time (there is a labor=burden setting in the resource group). Basically this setting is for if you have an employee clock into 3 different operations at the same time, is he running 3 machines at once? (you would accrue the actual time for burden, so all 3 operations would have as much burden as his labor. 3 ops for 1 hour = 1 hour labor and 3 hours burden, one for each op) or is he doing them one at at time? (this would be where you set burden = labor, 1 hour labor = 1 hour burden split between the 3 ops).
So if you really want to know how many labor hours are on an operation, if each employee clocks into the operation, it will capture that employees labor at the rate set up by the employee record.
