I would use the Sales/Gross Margin report (access it from the AR module).
You can sort by Product Group and it gives you Cost of Sales broken down by
its elements (Material, Labor, etc.).
Jim O'Donnell
Camcraft
jodonnell@...
In order to accurately determine labor cost is to be able to separate labor
by product groups. This is necessary due to the fact that different product
groups incur different proportions of the same type of labor (work center or
department), i.e. assembly, grinding, milling, etc. for dies versus molds.
Currently, the only way I see to come up with this type of reporting is to
manually go through the labor edit report and determine which jobs fall
under each product group and manually add them all up.
Jim O'Donnell
Camcraft
jodonnell@...
