Label Printers
We also use a Zebra T402. I modified the label that was in Vantage
(Crystal). We use 3 x 5 labels I believe. Works well. We print them
right along with the packing slips.
Juliet Martin
Although we're not ready to use barcoding (yet), we'd like to start printing labels at material receipt.
Could you make any hardware recommendations?
Environment: Warehouse; will be a network printer
To be labeled: Majority - stainless steel component raw material
TIA
Gail
I use the Datamax i4206's
http://www.datamaxcorp.com/products/i-class/
fast, reliable, moderately priced comes with Easy Label32 Pro bundle
option...
E. Lee Ingalls III
Information Systems Manager
Commercial Tool & Die, Inc.
ph: 616.785.8100 x.21
fx: 616.785.8210
www.commercialtool.com
TIA
Gail
At 11:23 AM 11/15/2000 , you wrote:
>I use the Datamax i4206's fast, reliable, moderately priced
Lee,
What's "moderately priced?" Also, does it use standard windows print
drivers? (ie: works with Crystal and other apps, no problem?)
Has anyone used those el-cheapo $200 Seiko label printers? I know
they look flimsy, but we have need for a low-volume label printer in a
couple places in our shop. If they work OK (even for a year or two) it
would be preferable to a high-dollar industrial label printer. Does Bic
make label printers? :)
-Wayne Cox
Wayne,
Moderate being relative... the $1800 was moderate compared to the S class or
other Zebra's of a comparable variety.
$1600-2300 depending upon options and software bundle. Ours run sun-up to
sun-up stopping only to change rolls.
I consider it mid point entry into industrial strength label printers.
Complete with NT drivers for printing from Crystal, etc...
E. Lee Ingalls III
fx: 616.785.8210
Lee,
-Wayne Cox
We want to install a printer in our shipping department to just print labels
from Vantage. I am assuming that this can be done. What printers are others
using to do this? Also, are there any "gotchas" to watch out for? Thank you.
Peter McGuire
Lovejoy Chaplet Corp.
pmcguire@...
(518) 686-5232
Fax: 686-4919
We're a little outdated right now. We're using the software program
Easylabel but still using our old Epson 1050 to print them out on (it's not
really made for label printing).
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
(810) 743-1600 ext.323
wpursche@...
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, March 09, 2001 10:07 AM
Subject: [Vantage] Label Printers
labels
others
you.
> Peter McGuire
> pmcguire@...
> (518) 686-5232
> Fax: 686-4919
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I'm using an Epson LQ-570 and modified the crystal form to print on a
standard UPS shipping label. Simple.
Terry L. Williams I.S. Manager Chipsco, Inc. 9936 Liberty St. Ext.
Meadville, PA 16335 814-333-6331 x236 fax: 814-337-2548 tlw@...
<mailto:tlw@...> www.chipsco.com <http://www.chipsco.com/>
Sent: Friday, March 09, 2001 10:08 AM
Peter McGuire
pmcguire@...
(518) 686-5232
Fax: 686-4919
Yahoo! Groups Sponsor
Click Here to Find Software Faster
<http://rd.yahoo.com/M=162801.1342103.2934627/D=egroupmail/S=1700007183:N/A=
599088/*http://www.knowledgestorm.com/jump_white.html?c=Yahoo&n=eLert_Comput
ersInternet_Software_WhiteGridTime&t=ad>
Great question, seeing as how I am also evaluating label printers. If I
could expand your question a bit I am wondering about thermal transfer label
printers such as from Zebra, Intermec, Datamax, etc.... Many of our
customers are requiring bar coded labels in a 4" X 6" format. I have used
Intermec with great success elsewhere (other systems) but they are
expensive. Media costs are an issue too. My biggest question is printing
straight from Crystal (modify a label from packing list .dbf data) and if
there are Windows drivers for this type of printer or if I have to use the
printer's control codes and 'store' formats (as with Intermec).
Otherwise I was considering a small laser printer with cut-sheet labels. I
don't trust dot matrix for bar codes.
-Todd Caughey
Harvey Vogel Mfg. Co.
Sent: Friday, March 09, 2001 9:08 AM
Peter McGuire
pmcguire@...
(518) 686-5232
Fax: 686-4919
ersInternet_Software_WhiteGridTime&t=ad> Click Here to Find Software Faster
<http://us.adserver.yahoo.com/l?M=162801.1342103.2934627/D=egroupmail/S=1700
007183:N/A=599088/rand=771787244>
We use Zebra 140xii and 105se printers throughout our shop for shipping
labels, pan tags, reject tags, etc. They are nice heavy duty printers in
metal cabinets (we tried the cheaper models in the plastic cases and they
broke down within a year. Our original 90 model (11yrs old) is still
running with limited maintenance (had to replace the drive belt twice)). I
have them connected to the network using HP Jetdirect print servers which
allows me to share them among the computers.
As for the labels, I found that the crystal reports worked but was too
limited unless using ODBC. We have several customers who want their
specific label design on their parts. We use Label Matrix to design and
print the labels. I have setup a user field on the Customer VBForm to
contain the name of the label format the customer requires, then added a
simple progress program to print labels on the Vantage menu. (The Progress
program dumps the Vantage Shipping data to a DBF file [just like crystal
does] for Label Matrix to read, then executes the Label Matrix print routine
with the label format defined in the Customer VBForm. All the shipping
person has to do is select the Packing slip number from a drop down box
(default to most current packing slip) and click the "Print Labels" button,
the number of labels is required is read off the packing slip line items.)
Michael Podlin
Peter McGuire
pmcguire@...
(518) 686-5232
Fax: 686-4919
Does anyone know anything about Eltron printers? Specifically their model
3742. The Zebra printers are quite expensive and the Eltron printers seem
like a less costly approach.
Peter McGuire
Sent: Friday, March 09, 2001 10:36 AM
To: pmcguire@...
Subject: RE: [Vantage] Label Printers
-Todd Caughey
Peter McGuire
pmcguire@...
(518) 686-5232
Fax: 686-4919
We have great success with zebra printers
Regards,
Keith
To: 'vantage@yahoogroups.com'
-Todd Caughey
Peter McGuire
pmcguire@...
(518) 686-5232
Fax: 686-4919
Long Business Systems, Inc.
12120 Elmwood Ave.
Cleveland, OH 44111
Phone: (216) 476-1416
Fax: (216) 476-1452
http://www.lbsi.com
