Known Bugs in 9.05.607
Good Morning,
I like to look at the online documentation avaialble at EpicWeb for the release notes for versions after mine, to see bugs to look out for. For example, go to documentation, pick Epicor 9, then look at Epicor905_ReleaseNotes_905607A. In the upcoming weeks, wait to see next version notes.
Sometimes I also find old version fixes that my version was supposed to fix, can be helpful to let me know what areas they really had significant problems in, for example if there are 30 fixes to AR Invoicing in a version prior to mine, I'd expect AR Invoicing to still be a little whacky.
Nancy
--- In vantage@yahoogroups.com, "greg_clauser" <gclauser@...> wrote:
> We're still only half implemented and finding a lot of wierd problems. There have been quite a few software bugs but sometimes the problems look like they could be a data entry or set-up parameter problem. Hard to tell most times. Unfortunately, we're on the latest E9 version so it would likely have the most bugs.
> Is there a place to look up known bugs so I don't spin my wheels?
I do searches at https://scrs.epicor.com/es9/Epicor9/search.htm when I find weird problems. Use your EpicWeb log information.
It doesn't give you a search of bugs by version though - searching a version looks like it just gives you what was targeted to be fixed in that version (still need to test it though, we've found "fixes" that didn't work). You really need to at least search on a module or specific issue.
Jenn
Hi Greg,
We have performed quite intensive testing on 9.05 607 and to date we have not uncovered any bugs. We have however raised a query why budgets are not showing on the Chart Tracker screen - this may turn out to be a bug. We have discovered by trial and error sometimes that the way Users need to perform transactions is quite different to Vantage 6.1 which is where we are moving from.
Jill Ribbons
Project Manager
[cid:image001.jpg@01CCB59F.54065370]
615 Goodwood Rd Panorama SA 5041 I PO Box 18 Melrose Park SA 5039
t: (08) 8275 0243 f: (08) 8277 0229 m: 0434 185 841
jribbons@... I www.bedfordgroup.com.au
Bedford - Providing the best options and opportunities for people with disability or disadvantage.
