I have a customer who want to have a new dashboard designed, in Kinetic for web access. Part of the requirement is to have a button the dashboard, either as a column button, or in a tracker view. When that button is pressed, the web user would be able to browse to a path on his computer and select an image file. The image file would then be encoded to base64, and sent as a parameter to an Epicor Function that would process the image, rename it, and copy it over to a server side OneDrive folder.
I know I can do all of this with a standard dashboard, but the question is, can it be done in a Kinetic dashboard accessed over the web?
1- Can you even have a button column in a Kinetic dashboard grid? Previously this would have to be added through a customization layer on the dashboard, by setting up the UltraGrid properties as needed…
2- Is it even possible to open a file upload dialog from a Kinetic dashboard event?
I have started some Kinetic development, but have not played much with Kinetic dashboards yet…
Do you have a basic example or explanation of how to set it up? I assume the “file upload process” is a widget available from within the button click event?
The file-transfer-erp widget seems to be the only one that fits the bill… How do I get the thing to open a browse dialog? As it is now, clicking the button does absolutely nothing.
I also wasn’t able to add a button column in the grid, the editor selection dropdown offers everything except a button, but I can live with this by adding the button to the grid header.
@HLalumiere You need to pair it with a File Picker Client component. That component will show the dialog window and allow you to pick the file. Once the file is picked you click your button and the fil-transfer-erp will grab that file. Use the ErpFileBoxID of the File Picker Client in your transfer Advanced settings.
I bound the Server Path Param to {TransView.FileName} and then bound the File Picker Client to {TransView.FileName} as well.
Otherwise the file was being upload with the name you set on the Param field. This way it grabs the file name from the client file you pick.
