Kinetic warehouse app
Have downloaded the Kinetic Warehouse app from Google play and installed on an android device.
How do I register for use ? Does it have to be the demo database? What are the server settings do I use net.tcp? Username and password?
Thank you
If you mean EMWW then if you do not have a licence then you can only use it in Demo mode
Was thinking that … what is the user name , password and server settings?
There is a config guide in Epicweb, helps setup the App server and URLs. The user name and password would come from the Epicor Education database. you can only use that database without a license.
Hello Bryan,
any requirement on the tablet. does it require a big ram like 8G. is it a 4G ram tablet ok.
thanks,
Eddy
I used the CK65, EDA51 and EDA71 without any issues. Not sure on the specs.
The app is basically a custom wrapper around a browser (probably the device’s default browser or
the Android WebView component, which is a cut down version of Chrome). If your device can view basic web pages, it should handle EWW.
thanks guys,
but we have scanner. so, we need connect scanner with the tablet.
any specific table required to connect a scanner?
thanks,
Eddy
