Kinetic Upgrade - Custom Code Query
Hi
Can somebody give me a pointer on this line of code below that compiles on 10.2.300, but fails to compile on 2022.1.
var dynamicCriteriaReport = WCFServiceSupport.CreateImpl<Ice.Proxy.Rpt.DynamicCriteriaImpl>((Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.DynamicCriteriaSvcContract>.UriPath);
The error I’m getting is:
Error: CS0117 - line 313 (735) - ‘Epicor.ServiceModel.Channels.ImplBase’ does not contain a definition for ‘UriPath’
Is it a write to use REST, move away from WCF? Or a tweak to syntax? I have seen some Kinetic Code examples that do use the WCFServiceSupport.
Many Thanks
Mark
Running into a meeting but maybe @josecgomez or @jgiese.wci have already figured this out.
In a nutshell what I see is that Epicor got rid of
ImplBase<TContract>
They still have ImplBase and they still in their Client code get the UriPath from the Client Side via something like
aRInvoiceLoadBO = WCFServiceSupport.CreateImpl<ARInvoiceLoadImpl>( Session, ARInvoiceLoadImpl.UriPath);
EDIT
Josh said
Just went through and updated the calls. They put the uri in the contract object.
Try
Ice.Proxy.Rpt.DynamicCriteriaImpl.UriPath
@hkeric.wci @jgiese.wci you’re both legends as always.
I managed to get it updated based on your advice.
Couple of usings at the top:
using Ice.Proxy.Rpt;
using Ice.Contracts;
and then updated my line to read:
var dynamicCriteriaReport = WCFServiceSupport.CreateImpl<DynamicCriteriaImpl>((Session)oTrans.Session, DynamicCriteriaImpl.UriPath);
THANK YOU! :+1:
That’s excellent. Now you have time to get some badly needed REST.
:wink:
Nice Mark! :rofl:
