I have searched so for recommended server setup for Kinetic 2022. I am going to launch a new 2022 VMware server, but would be helpful what Epicor recommends on provisioning. under 50 Users and will have a seperate SQL and application servers.
Hi Matthew,
We can’t share the official Epicor documents directly, but as as Epicor customer you should have access to the ‘EpicWeb’ portal, which contains all the software downloads, guides and other documents.
One of the guides is titled ‘Architecture Guide’, and describes different infrastructure setups for different number of users, etc.
A direct link is very handy to have, because it sure is difficult to find by searching for it! Epicor actually has two separate Kinetic hardware sizing guide files available in their Resource Library (Document Class: System Requirements). Why both are available, I have no idea!
