Anyone see this before. Have my search-show widget setup, loads the results. Then when you select a row and click OK nothing happens, no error in the console either
Do you have the search-value-set widget following your search-show widget?
Although it is interesting to see your search window just hang there.
I initially had the search-value-set widget but same result, tried removing it a just putting a show dialog of the search result. OK button just never does anything. Works fine if Search Type is basic
Hi, did your BAQ search work?
Even though we selected the BAQ search it is calling basic search and thus I couldn’t retrieve the additional BAQ fields.
