joerojas
(Joe Rojas)
November 7, 2022, 3:33pm
1
Hi All,
I didn’t see this specific idea in Kinetic Ideas so I created one.
I wanted to share in case anyone would like to vote for it.
https://epicor-manufacturing.ideas.aha.io/ideas/KNTC-I-2964
TerryR
(Terry Raymond)
November 7, 2022, 4:16pm
2
I think the built in change log tables are limited to the tables that have View Change Log buttons on the user interface screens.
Can you give an example of an unsupported table that you are needing to log?
I’ve never found a table I couldn’t create a change log for . . . just add it under data directives?
askulte
(Andris Skulte)
November 7, 2022, 6:15pm
4
Some UI’s don’t have the ‘view change log’ icon available, but all (at least the one’s I’ve needed) had the ability to add change log recording via a data directive.
We are able to add change log icon in toolbar for forms which don’t have change log enabled. I did it for Non Conformance and worked well- like base change log in part. Thanks to our group per: https://www.epiusers.help/t/change-log-viewer-manual-add/45158 .
While converting this functionality in kinetic layer, I start looking at Part- but can’t find change log in details > tools. When we click on change log, it will open up slider panel for change log. I am not able to trap and debug for the ve…
Greetings All.
Working on E10, version 10.2.100.6. User wants to manually add to change log. I have BPM to collect data, so the viewer is accurate. The “New” icon does not work in Viewer, so I am wondering if that is even an available option. Any of you folks know if it is a rights issue or a somethin’ somethin’?
