Not sure what’s going on, but I can’t seem to get a very, very simple function to recognize the response parameters. I create a function with just one response parameter called “outParm” of type System.String.
For the function, I’ve tried two approaches. One was a function with custom code with one line:
this.outParm = "Test";
The other was a widget driven function with the widget setting the parameter to the value of “Test”.
When I run either of these functions through Schedule Epicor Function, they throw an error to the system monitor:
I’ve tried promoting the library to production. In the custom code, I used the context menu to add the “this.outParm” (saw that was an issue from a previous post). Am I missing something real simple?
Solution is “There are bugs in the function designer”. I assumed the function designer was a bit more developed at this point.
The code was made fresh just for this example. Literally, created a new custom code function, added the output parameter, and added the one line of code to set it to a value. Everything compiled clean. Just the runtime error. It’s been a while since I’ve created a function with output parameters, was thinking perhaps I had a brain fart and missed an easy step.
We’ll be on 2023.2 before long, maybe it will be mysteriously fixed then. In the meantime, I had a few different ways to address my core solution, so I’ll move onto plan B.
