Has anyone dealt with Kinetic dashboards… I have a dashboard that needs parameters instead of a tracker filter. Everything works great except anytime you try to filter or sort the grid view it acts like I am refreshing it and calls for the parameters. I can’t find any events or triggers around that would cause it, so I am at a loss.
Has anyone encountered this and found a workaround?
I have also encountered this. If your tracking it via a ticket or problem number please share, BAQ parameters seem to go against Kinetic grid thinking.
I’ve been removing BAQ parameters when possible but also finding it very time consuming reporting all the issues. Some it just a learning curve but it’s not a clean migration by any means.
Just had the revelation that this is likely because kinetic isn’t storing that data anywhere… It is just being placed in the front end for viewing, so anytime you try to slice the data it is going back to the back end to get the data…
Kinetic only brings a hand full of records, then if you scroll it grabs more. The kinetic browser behaves differently and this inadvertently triggers the parameters prompt again.
Whenever I uplift dashboards, I typically completely overhaul them. Literally everything. Remap, restructure, rearrange (some other “re”). Dashboards uplift terribly.
So I guess this adds to the premise that they launch a product that was not ready for release !
We too use a lot of dashborad using BAQ parameters. very practical…
Hannah: Question: When you say the parameters window appears again, is the result comming back would correspond to the next set of records, or the initial set ?
Also, are the parameters values present or you have to re-enter then each time?
Design your BAQ with parameters and get it working the way you would like.
When it is final, copy your BAQ and gut it down to just the top level. It doesn’t
even need to work at all, just must compile/save.
(No parameters in this BAQ)
Use Advanced BPM Update to override the GetList.
In the GetList BPM, pull your where clauses ( “Parameters” ) out of the
executionParams.ExecutionSetting and use the dynamic query adapter to call your original BAQ
with the parameters you parsed from the where fields.
Replace the rows in the called BAQ with the ones from the real BAQ and Bob’s your uncle.
Kinda Hokey, but if you need this functionality now, it can be finagled.
It grabs a certain number of records for paging (looks to be about 300 based on Dev Tools).
When you scroll past that, the parameter window comes up again (with no previous value) and you have to enter the same value to get the next 300 results.
Something I just noticed too… you lose the first 300 results after entering the parameter again… Neat. Nevermind. That was just a glitch, I guess. Shocking.
Lemme play with it. I’ve messed with the execution settings before in dynamic query REST calls, so I’m sure there’s a way to pass in the ExecutionParameter field.
