Kinetic Dashboard Group By Summaries, Save Layout
I have built a Kinetic dashboard in version 2024.2.10. In the Panel Card Grid I have check marked Show Filter and Group Options. My goal is to group by summaries just like is the post Kinetic Dashboard Group By Summaries. After dragging Category to the Group By area and clicking Show Summaries, this is my result.
I have tried to Save Layout but this display will not save. I have tried to Save a Personalization but still no luck saving this display. Is there any way to save the grouped by and summary setting to a Kinetic dashboard?
I wonder if your user account does not have the Allow Personalization right enabled?
Thank you for the reply. I appreciate you helping with my issue.
Yes, I have allow personalization checked for my user account. I am able to hide columns and change column size on other screens and save the personalization successfully. But I am unable to save the layout for group by and show summaries on a custom built dashboard.
Thank you,
Heide
Can we determine this is related to a custom dashboard or not? What happens if you open the Sales Order Shipment dashboard and try to group by the Packing Slip?
Hi Simon,
At the 3 dots I can see Show Summaries and Personalize Columns. I do not have Group By.
I can show summaries successfully and save the layout and it will stay.
I can successfully hide columns and save the personalization using Personalize Columns.
In my custom dashboard, for me to be able to group by, I must click the Panel Grid Card, go to Advanced, and then check Show Filter and Group By Options (in application studio).
For the standard Sales Order Shipment screen, I must go to application studio, and check show filter and group by. Customizing this screen is the only way that I know to group by. I can save the customization with its group by.
I can play the layer and see the group by. Then I published the layer and linked the customization to the menu.
As of right now, I can not see the group by on the published layer that I assigned to the menu customization. I know that when opening the menu that I am on the new layer because I see this in the URL.
I can see the summaries, I still have my personalization, but no group by at the 3 dots and no group by from my customized layer.
I could be doing something wrong, that is why I listed all my steps in case I made an error.
We are on version 2024.2.12 and are Public Cloud SaaS with the latest updates.
When you run the dashboard not in Application studio, can you just click on the filter then drag the column to group then save layouts?
Dashboard Group by
Then you could convert your personalization to a new layer.
Thank you for the picture and video. It was helpful. I get so stuck on one path. Thank you for redirecting me to use the little filter or group by icon.
I used the little icon to make the group by. Then I dragged the category into the column header. Then I saved layout.
If I have the group by set before refreshing the data, then I get all zeros in all the lines.
If I clear the group by, refresh the data, wait for the data to load, and then drag the category into the group by, the screen will show accurate data.
Thank you,
Heide Warren
The same issue is happening on the Sales Order Shipment screen, a standard Epicor screen. I dragged the Pack Slip to the group by and saved the layout. The next time I loaded the screen and the data refreshed with the group by already there, I receive all zeros for all the lines.
I have created an EpiCare ticket and will report back.
EpiCare responded and said “There have been issues like this logged with development”. The ticket is In Progress.
