Shape [of you?]
Allows a user to customize a color and shape based on different statuses.
Property Group | Property | Description |
Basic | Id | Unique identifier for the control |
Behavior | On Blur | Click this to create an OnBlur event for the control. On Blur is triggered when the control loses focus. |
Behavior | On Create | Click this to create an OnCreate event for the control On Create is triggered when the control is painted to the GUI. |
Comments | Comments | Add some developer notes to the control. These are not customer-facing and are only visible in App Studio (Fig. A) |
Data | Key Field | Indicates that a bound component is a key field. If true, the field is enabled if there is no current record, allowing the user to select an existing record or create a new one. |
Data | EpBinding | Bind the control to a DataView.Column. Set this to apply row rules to the shape. |
Layout | Alignment | Sets the alignment of the control. (Fig. B) |
State | Personalizable | If true, a user can personalize this component(hide/show) |
State | Customizable | If true, a user can customize this component in child layers |
State | Hidden | Hides the control from view. |
State | Disabled | Disables the control. The control will not allow editing or focus. |
State | Read Only | Makes the control read only so that it will not allow editing. The control can still be focused. |
Advanced | Enabled Caption | Set the text to show when the shape is enabled. |
Advanced | Disabled Caption | Set the text to show when the shape is disabled. |
Advanced | Status | Set the status to change the color of the shape. Valid options include: OK, Warning, Stop, Global, and None which are Green, Yellow, Red, Blue, and None, respectively. |
Figure A: Comments
Figure B: Alignment
