I created a Classic Combo box to pull in the Customer Name into a UD field using the properties below. I’ve tried re-creating in Kinetic but cannot get it to display the Customer.Name in the drop down list to select from using a Combo box. Also, does Classic customizations such as combo boxes auto convert over to Kinetic when deployed in Kinetic form?
Create a ERP-Combo.
Give it an ID and Label Text
Bind it: I am using TransView.CustNum
Set the type
and Subtype: Default - This is base configuration (boiler plate from Epicor)
Under advanced.
You can add your filters e.g
and…
The classic to kinetic conversion tool is shit… Better of adding it from the start…
That worked, thanks!
