But the problem there is that that “shortcut” window can’t have tabs, I guess. Any new “tabs” open in another normal browser window (with the normal browser icon).
And if you want to add some security pizazz, you can modify the shortcut to open in In-Private/Incognito mode, disable extensions, or pick a particular profile, etc.
And speaking of cheese movement and profiles, y’all are going to start to see a briefcase on your Edge icon if you’re logged into a Microsoft Work or School account. This is in the latest Windows 11 updates.
OK since I TLDR’ d the last time I’ll do one more that will hopefully be a little better.
Chrome now supports something called Multiple Profiles. This allows you to create a Profile in Chrome that is completely separate from the other profiles in your account (including extensions, favorites etc) this also gets a Custom ICon on the taskbar
In Chrome Click on your Profile Picture Top Right and Click Add Under Other Profiles
All tabs open within this browser profile will be grouped under that icon you selected
If you wanna get extra fancy create a google account and set its “image” to the epicor shortcut then that can be the icon that shows up on the taskbar.
