A month or two ago, KBMax Configurator quietly appeared in the list of configurator types in Configurator Entry. I’ve been tasked with investigating whether we want to use them. But if you create a new configurator, select KBMax Configurator, and try to save, you just get an error that says:
KBMax Configurator must be selected.
Is the error referring to a module? I don’t see a module related to KBMax in Company Configuration. We do have Advanced Configurator enabled.
Kevin, did you buy KBMax configurator? I’d have a conversation with your CAM. It’s a whole new thing… I’m assuming those settings are to allow it to work once you’ve bought it. Similar to Mattec/AdvancedMES, Avalara, SalesForce, DocLink, Credit Cards, etc…
I figured it would be a new module, but it’s not even listed as a module we don’t have. Last I heard, it wasn’t supposed to be available until the end of the year. Maybe it showed up prematurely as a choice in Configurator Entry.
