Kanban Functionality in Epicor pros and cons
Hi all,
I just want to know which is your experience or what do you think about the Kanban functionality in Epicor 9.05.701 , if you had done it for Purchasing better . We are trying to add new customization to the Kanban but I want to know first if you had any concerns or problems while doing so, kind of like the pros and cons .
My problem is that when epicor creates the PO, my inventory could keep reducing . So when we receive the order our inventory is still less than our minimum quantity and if is less than our minimum the Kanban wont be trigger again. Is this an issue with the application?
Thanks a lot.
