Here is what is strange; if we unreceive an existing receipt then we can
receive it. But 9 won't even show the lines of a PO when attempting a
new receipt.
After converting from 8.03 to 9.0 the following does not work after very
limited testing:
Get Details during job creation
Cannot receive a PO
Cannot print a quote after adding text to a quote line
We have an Epicor 9 review next Wednesday. I'll post all of the issues
that we have found. If you have any suggestions as to why the functions
above do not operate, please let me know. Thanks
Regards,
Andrew Best
Kice Industries, Inc.
P(316)744-7151
F(316)295-2412
Of Andrew Best
Sent: Thursday, January 14, 2010 10:42 AM
Subject: RE: [Vantage] Just converted to Epicor and we are having Lots
of issues
FYI, this is not working on PO's converted from 8.03 or on PO's that are
newly created in 9.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of Andrew Best
Sent: Thursday, January 14, 2010 10:36 AM
of issues
Any ideas on this problem?
PO Receiving error: not seeing items on POs that are open and have
items to receive
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of Andrew Best
Sent: Thursday, January 14, 2010 10:26 AM
of issues
That fixed it, thanks. It would have been nice for Epicor to let us
know about this.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of advantage
Sent: Wednesday, January 13, 2010 6:43 PM
of issues
Yes, Run Coversion Program 160. It has to do with activating the sandard
posting rules for all transaction types.
PROBLEM DESCRIPTION
PM Error "Expense account cannot be determined" while saving a PO line
PROBLEM RESOLUTION
Financial Management > General Ledger > Setup > GL Transaction Type
Search/Enter PO Release Transaction Type > OK
Verify there is not an Active revision for the current version of the
software.
You will need to import the posting rules for the PO Release Transaction
Type using the following instructions:
1. Actions > Import ACTType
2. Browse and select all files PO_Release.xml from
//server/postingrules/standard.
3. Check all 3 boxes in the lower left corner and Click OK.
4. Select the Book you are mapping the rules to (the Main Book).
5. If importing multiple tran types select the checkbox in the bottom
left
corner to avoid getting prompted for every rule.
If you are unable to import the posting rules with the above
instructions,
you will need to run database conversion programs 9900 and 9980, and
import
again.
VERSION 9.04.504B
Behalf Of
Andrew Best
Sent: Wednesday, January 13, 2010 5:28 PM
Subject: [Vantage] Just converted to Epicor and we are having Lots of
issues
Good thing this is only a test.
I am receiving this error when trying to create a PO. Any ideas?
Transaction Type "PO Release" was not found.
Expense account cannot be determined.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
new receipt.
limited testing:
Cannot receive a PO
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Of Andrew Best
of issues
newly created in 9.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of Andrew Best
of issues
items to receive
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of Andrew Best
of issues
know about this.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Behalf
Of advantage
of issues
PROBLEM DESCRIPTION
PROBLEM RESOLUTION
software.
left
instructions,
import
again.
VERSION 9.04.504B
Behalf Of
Andrew Best
issues
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
