I need to log the create date when Material is added to the Job. How would I go about doing this?
Depending on what you want to use it for, you could just enable the Change Log for JobMtl (Data Directive). If you’re just trying to figure out who changed/added what, that might work. If you want to report on it, I would maybe add a UD field.
Thanks, got it
