JobHead table fields
Where on the Job Entry screen would I find the fields JobHead.WIName and JobHead.EquipID?
I do not know the answer, but I would go to the Data Dictionary Viewer and pull up JobHead and see what they have for a description.
I do not think you will see EquipID on Job Entry Screen, only Maintenance Job Entry screen.
how do I get to Maintenance Job Entry screen?
Do you own the Maintenance Module?
I do not believe so based on the company configuration licenses
I am trying to set a field from the OrderRel table to be sent to the table that the JobTraveler filter screen job grid is on. Unless there is a way to add my custom column to that table specifically from the OrderRel table
