Those steps are right. If only some of your jobs are make to order,
then change it to a left join. And you might need to fiddle with the
crystal report format or formulas later to prevent a large blank spot on
the page where the address would go.
Brian.
Of randy.hunter75
Sent: Monday, August 20, 2012 9:04 AM
Subject: [Vantage] Re: Job Travler report data definition 9.05.607B
Brian
Thanks for your response. I'm still missing something however. I was
taking this one step (table) at a time. I added the jobprod table to the
report defintion and created a relationship between jobhead,jobprod
(company + jobnum), ran the report using the definition, set the
datasource in crystal to the xml file, added the table to the report and
matched the links in crystal to what I used in the data definition. This
part worked fine. I browsed data in the field explorer and everything
was fine. I could add fields to the report.
I then added the orderhed to the defintion, linked on company+ordernum,
updated the report data defintiion and I get no data in the orderhed
fields. If I add fields to the report, I get a blank report. I assume
this is from the inner join finding nothing.
What do you think I'm missing here?
Thanks in advance
"Brian Roberts" <broberts@...> wrote:
Behalf
Brian.
Of randy.hunter75
Brian
Thanks in advance
>can
> Jobs are linked to orders via the JobProd table, and from there you
> link to OrderHed by Company+OrderNum. To get the actual customer name&
> ship to address, you'll need the Customer or ShipTo table.[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> In general, if you know what tables you want but not how to link them,
> try adding both tables in the BAQ builder and seeing how it
> automatically links them. Doesn't always work, but an easy shortcut.
> Brian.
Behalf
> Of randy.hunter75[Non-text portions of this message have been removed]
> Sent: Friday, August 17, 2012 10:28 AM
> Subject: [Vantage] Job Travler report data definition 9.05.607B
> I'm trying to add several fields to our job traveler. PO # and ship to
> address from the Sales order. Any advice on the proper table
> relationships in the data defintion to get this information?
> Thanks in advance for any help
