Hello Everybody,
I’ve recently been asked to create a system in our job traveler to print attachments with the report, pulled from the Job entry module. Using Epiusers I was able to get my hands on some code to customize the form, but I am running into a strange error and am having trouble debugging.
I have somewhat of a programming background, but am very new and unfamiliar to the operations of Epicor, so any help would be greatly appreciated!
<extern alias Erp_Contracts_BO_JobAsmSearch;
extern alias Erp_Contracts_BO_JobEntry;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using System.IO;
using System.Collections.Generic;
using Erp.BO;
using System.Text;
using Ice.Core;
using Erp.Proxy.BO;
public class Script
private EpiDataView edvJobList;
private EpiDataView edvAsmList;
StringBuilder Texte = new StringBuilder();
edvJobList = ((EpiDataView)(this.oTrans.EpiDataViews["jobList"]));
edvAsmList = ((EpiDataView)(this.oTrans.EpiDataViews["assemblyList"]));
this.epiButtonC1.Click += new System.EventHandler(this.epiButtonC1_Click);
edvJobList = null;
edvAsmList = null;
this.epiButtonC1.Click -= new System.EventHandler(this.epiButtonC1_Click);
Texte = null;
// Begin Custom Code Disposal
// End Custom Code Disposal
private void JobTravForm_Load(object sender, EventArgs args)
SetVersionNumber(JobTravForm);
private void SetVersionNumber(EpiBaseForm form)
string custName = oTrans.EpiBaseForm.CustomizationName;
string version = "Edit";
if (custName.LastIndexOf("_") >= 0)
version = custName.Substring(custName.LastIndexOf("_") + 1, custName.Length - custName.LastIndexOf("_") - 1);
form.Text = form.Text + " - Peter Adams " + version;
private void epiButtonC1_Click(object sender, System.EventArgs args)
if (edvJobList.dataView.Table.Rows.Count > 0)
Ice.Core.Session epiSession = default(Ice.Core.Session);
epiSession = (Ice.Core.Session)JobTravForm.Session;
JobEntryAdapter JobEntryBO = new JobEntryAdapter((Ice.Core.Session)oTrans.Session);
DataTable tempTable = new DataTable();
tempTable.Columns.Add("JobNum", typeof(string));
tempTable.Columns.Add("PartNum", typeof(string));
tempTable.Columns.Add("FileName", typeof(string));
tempTable.Columns.Add("AsmSeq", typeof(string));
tempTable.Columns.Add("ParentPart", typeof(string));
foreach (var value in tempTable.Columns)
MessageBox.Show(value.ToString());
for(int x=0; x < edvJobList.dataView.Table.Rows.Count; x++)
Ice.Lib.Searches.SearchOptions opts = new Ice.Lib.Searches.SearchOptions(SearchMode.AutoSearch);
string whereClause = string.Format("JobNum = '" + edvJobList.dataView.Table.Rows[x]["JobNum"].ToString() + "'");
opts.PageSize = 0;
opts.AbsolutePage = 1;
opts.NamedSearch.WhereClauses.Add("JobHead",whereClause);
opts.DataSetMode = Ice.Lib.Searches.DataSetMode.RowsDataSet;
bool morePages = false;
var jobEntryDS = (Erp.BO.JobEntryDataSet)JobEntryBO.GetRows(opts,out morePages);
foreach(DataRow hr in jobEntryDS.Tables["JobHead"].Rows)
MessageBox.Show(hr["JobNum"].ToString());
else
MessageBox.Show("Test");
