I have a custom version of the Job Traveler where I am trying to pull in the prime warehouse and bin for each raw material in the job as well as the part being produced. Problem is that I join to the PartPlant and PlantWhse tables on the JobHead table to get the prime warehouse and bin for the main part, but then can’t join in the RDD on the JobMtl table as well to get the fields for the raw materials!
Anyway around this? I’ve tried inner selects within the RDL file to get the fields specifically to no avail. RDL query below:
="SELECT JH.Company, JH.JobNum, JH.PartNum, JH.Calc_MultiJobParts, JH.PartNum_ShortChar04, JH.PartNum_ShortChar06, JH.PartNum_ShortChar10, JH.PartNum_ClassID, JH.PartNum_MtlAnalysisCode, JH.StartDate, JH.DueDate, JH.ShortChar01, JH.Number01, JH.SchedCode_Description, JH.ProdQty AS JobHead_ProdQty, JP.TargetJobNum, JP.OrderNum, JP.OrderLine, JP.OrderRelNum, JP.ProdQty, JA.AssemblySeq, JA.Calc_comment, JA.StartDate AS JA_StartDate, JA.PartNum_CheckBox07, JO.OprSeq, JO.OpCode, JO.RunQty, JO.Machines, JO.EstSetHours, JO.EstProdHours, JO.StartDate AS JobOper_StartDate, JO.DueDate AS JobOper_DueDate, JO.Calc_DispStatus, JO.ProdStandard, JO.OpCode_OpDesc, JO.OpDesc, JO.VendorNum_VendorID, JO.CommentText, JO.Calc_OPText, JO.FAQty, JO.PrimaryProdOpDtl, JO.PrimarySetupOpDtl, DENSE_RANK() OVER(PARTITION BY JA.Company, JA.JobNum ORDER BY JA.Company, JA.JobNum, JA.AssemblySeq) AS RunCountJobAssy, JAI.AssyCount, JA.RevisionNum, JA.Description, JOD.ResourceGrpID, JOD.ResourceGrpID_Description, JOD.OpDtlSeq, JOD.SetUpCrewSize, JOD.SetupOrProd, JOD.ProdCrewSize, JOD.ConcurrentCapacity, JOD.DailyProdRate, JOD.Calc_SchedResGrpDesc, JOD.Calc_ResGrpDesc, JOD.Calc_SchedResDesc, JOD.Calc_ResDesc, JOD.Calc_CapbltyDesc, JOD.CapabilityID, JOD.ResourceID, PW.WarehouseCode, PW.PrimBin, RG.JCDept_Description, RG.InputWhse, RG.Description AS RG_Description, (SELECT STRING_AGG(JM1.PartNum, CHAR(10)) FROM JobMtl_" + Parameters!TableGuid.Value + " JM1 WHERE JM1.JobNum = JH.JobNum AND JM1.AnalysisCode IN ('1003', '1010', '1030', '1045', '1050', '1061', '1066', '1073')) AS SteelList, SA.Parent, SA.Calc_ParentNum, SA.Calc_ParentDesc, SA.RelatedOperation, SA.AssemblySeq AS SubAsmbl_AssemblySeq, SA.PartNum AS SubAsmbl_PartNum, SA.Description AS SubAsmbl_Description, SA.RequiredQty AS SubAsmbl_RequiredQty, SA.PullQty AS SubAsmbl_PullQty, SA.IUM AS SubAsmbl_IUM, SA.WarehouseCode AS SubAsmbl_WarehouseCode, SA.Calc_DispStatus AS SubAsmbl_Calc_DispStatus, JM.MtlSeq, JM.RelatedOperation AS JobMtl_RelatedOperation, JM.PartNum AS JobMtl_PartNum, JM.PartNum_PartDescription, JM.PartNum_ShortChar04 AS JobMtl_PartNum_ShortChar04, JM.PartNum_ShortChar07 AS JobMtl_PartNum_ShortChar07, JM.RequiredQty, JM.IUM, JM.BackFlush, JM.IssuedComplete, JM.IssuedQty, JM.Ordered, JM.CheckBox01, JM.AssemblySeq AS JobMtl_AssemblySeq, JM.QtyPer, XFR.ShortChar01 AS XFR_ShortChar01, XFR.ShortChar02 AS XFR_ShortChar02, XFR.ShortChar03 AS XFR_ShortChar03, XFR.DocTypeID, ISNULL(RTU.ResourceGrpID, '') AS ResourceTimeUsed_ResourceGrpID, ISNULL(RTU.ResourceID, '') AS ResourceTimeUsed_ResourceID, PR.Name, CY.Calc_APSAvailable, PW.WarehouseCode AS PlantWhse_WarehouseCode, RG.InputWhse AS ResourceGroup_InputWhse, PO.PONum, PO.ReceivedQty AS PO_ReceivedQty, WB.Character01, JM.PartNum_QtyBearing, JM.PartNum_ClassID AS JM_PartNum_ClassID,
(SELECT TOP 1 PPI1.PartNum FROM JobMtl_" + Parameters!TableGuid.Value + " AS JMI1 LEFT OUTER JOIN PartPlant_" + Parameters!TableGuid.Value + " AS PPI1 ON CStr(JMI1.PartNum) = CStr(PPI1.PartNum) AND PPI1.PartNum != '') AS TEST,
(SELECT WI1.Number01 FROM JobMtl_" + Parameters!TableGuid.Value + " AS JMI1 LEFT OUTER JOIN PartPlant_" + Parameters!TableGuid.Value + " AS PPI1 ON JMI1.PartNum = PPI1.PartNum LEFT OUTER JOIN PlantWhse_" + Parameters!TableGuid.Value + " AS PWI1
ON PPI1.PartNum = PWI1.PartNum AND PPI1.PrimWhse = PWI1.WarehouseCode LEFT JOIN Warehse_" + Parameters!TableGuid.Value + " WI1 ON WI1.Plant = PWI1.Plant AND WI1.WarehouseCode = PWI1.WarehouseCode WHERE JMI1.JobNum = JM.JobNum AND JMI1.PartNum = JM.PartNum ) AS JM_Bldg,
(SELECT PWI2.WarehouseCode FROM JobMtl_" + Parameters!TableGuid.Value + " AS JMI2 LEFT OUTER JOIN PartPlant_" + Parameters!TableGuid.Value + " AS PPI2 ON JMI2.PartNum = PPI2.PartNum LEFT OUTER JOIN PlantWhse_" + Parameters!TableGuid.Value + " AS PWI2
ON PPI2.PartNum = PWI2.PartNum AND PPI2.PrimWhse = PWI2.WarehouseCode WHERE JMI2.JobNum = JM.JobNum AND JMI2.PartNum = JM.PartNum) AS JM_PrimWhse,
(SELECT PWI3.PrimBin FROM JobMtl_" + Parameters!TableGuid.Value + " AS JMI3 LEFT OUTER JOIN PartPlant_" + Parameters!TableGuid.Value + " AS PPI3 ON JMI3.PartNum = PPI3.PartNum LEFT OUTER JOIN PlantWhse_" + Parameters!TableGuid.Value + " AS PWI3
ON PPI3.PartNum = PWI3.PartNum AND PPI3.PrimWhse = PWI3.WarehouseCode WHERE JMI3.JobNum = JM.JobNum AND JMI3.PartNum = JM.PartNum) AS JM_PrimBin
FROM JobHead_" + Parameters!TableGuid.Value + " JH
LEFT OUTER JOIN JobProd_" + Parameters!TableGuid.Value + " JP ON JH.Company = JP.Company AND JH.JobNum = JP.JobNum
LEFT OUTER JOIN XFileAttch_" + Parameters!TableGuid.Value + " XFA ON JH.Company = XFA.Company AND JH.JobNum = XFA.Key1
LEFT OUTER JOIN XFileRef_" + Parameters!TableGuid.Value + " XFR ON XFA.Company = XFR.Company AND XFA.XFileRefNum = XFR.XFileRefNum
LEFT OUTER JOIN JobAsmbl_" + Parameters!TableGuid.Value + " JA ON JP.Company = JA.Company AND JP.JobNum = JA.JobNum
LEFT OUTER JOIN JobOper_" + Parameters!TableGuid.Value + " JO ON JA.Company = JO.Company AND JA.JobNum = JO.JobNum AND JA.AssemblySeq = JO.AssemblySeq
LEFT OUTER JOIN (
SELECT JA1.Company, JA1.JobNum, COUNT(DISTINCT JA1.AssemblySeq) AS AssyCount
FROM JobAsmbl_" + Parameters!TableGuid.Value + " JA1
JOIN JobOper_" + Parameters!TableGuid.Value + " JO1 ON JA1.Company = JO1.Company AND JA1.JobNum = JO1.JobNum AND JA1.AssemblySeq = JO1.AssemblySeq
GROUP BY JA1.Company, JA1.JobNum) JAI ON JA.Company = JAI.Company AND JA.JobNum = JAI.JobNum
LEFT OUTER JOIN JobOpDtl_" + Parameters!TableGuid.Value + " JOD ON JO.Company = JOD.Company AND JO.JobNum = JOD.JobNum AND JO.AssemblySeq = JOD.AssemblySeq AND JO.OprSeq = JOD.OprSeq
LEFT OUTER JOIN PartPlant_" + Parameters!TableGuid.Value + " PP ON JH.Company = PP.Company AND JH.Plant = PP.Plant AND JH.PartNum = PP.PartNum
LEFT OUTER JOIN PlantWhse_" + Parameters!TableGuid.Value + " PW ON PP.Company = PW.Company AND PP.Plant = PW.Plant AND PP.PrimWhse = PW.WarehouseCode AND PP.PartNum = PW.PartNum
LEFT OUTER JOIN ResourceGroup_" + Parameters!TableGuid.Value + " RG ON JOD.Company = RG.Company AND JOD.ResourceGrpID = RG.ResourceGrpID
LEFT OUTER JOIN SubAsmbl_" + Parameters!TableGuid.Value + " SA ON JA.Company = SA.Company AND JA.JobNum = SA.JobNum AND JA.AssemblySeq = SA.Parent
LEFT OUTER JOIN ResourceTimeUsed_" + Parameters!TableGuid.Value + " RTU ON JOD.Company = RTU.Company AND JOD.JobNum = RTU.JobNum AND JOD.AssemblySeq = RTU.AssemblySeq AND JOD.OprSeq = RTU.OprSeq AND JOD.OpDtlSeq = RTU.OpDtlSeq
LEFT OUTER JOIN JobMtl_" + Parameters!TableGuid.Value + " JM ON JH.Company = JM.Company AND JH.JobNum = JM.JobNum
LEFT OUTER JOIN Person_" + Parameters!TableGuid.Value + " PR ON JH.Company = PR.Company AND JH.PersonID = PR.PersonID
LEFT OUTER JOIN Company_" + Parameters!TableGuid.Value + " CY ON JH.Company = CY.Company
LEFT OUTER JOIN PORel_" + Parameters!TableGuid.Value + " PO ON JM.Company = PO.Company AND JM.JobNum = PO.JobNum AND JM.MtlSeq = PO.JobSeq
LEFT OUTER JOIN WhseBin_" + Parameters!TableGuid.Value + " WB ON PW.Company = WB.Company AND PW.WarehouseCode = WB.WarehouseCode AND PW.PrimBin = WB.BinNum "```
