That method works, except costing can be a real pain depending on your methods. By default the cost of the materials will be equally distributed across the parts produced. There is a ratio on the job part tab that can be used to influence it but it's not perfect.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of that_guyy
Sent: Wednesday, September 05, 2012 5:32 AM
Subject: [Vantage] Re: Job to strip components of an RMA item back to inventory.
Here is what I used to do:
Create a multi-part Job (In Job Entry under the Parts tab), these would be the parts to go back into inventory. (in 9.05.700 is is called Co-Parts)
Add one operation to report any desired labor against the Job.
Add one material, the whole RMA'd Finished Good. (maybe optional in 605, I don't remember, I would add it anyways and remove it later if not needed).
Then on the Quality module side of things:
Fail the RMA in RMA disposition to DMR
In the DMR Accept the parts as Job Material to the Job and Mtl Seq you just created. The DMR will then be closed.
Strip the parts, report qty and/or time against the operation
Mfg receipt into stock, on this screen you will need to go to the `Parts' tab and enter your qtys to return to stock in the list.
