Job to Job transactions
I know I am extremely late with the THANK YOUs but, thank you all for the response on this topic.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
Sent: Tuesday, March 13, 2012 4:48 PM
Subject: RE: [Vantage] Re: Job to Job transactions
It's been a while since I reviewed the job-to-job costing methods, we are average cost here, if my memory serves me, I thought that the costs were rolled up from the supply job as material to the parent job (though at the assembly\cost tab you can still see the costs for the labor and burden and material from the supply job). The individual cost drivers are still available on the supply job as well, so you can see them from that angle..
I sort of see where they are coming from with regards to how this works if you're on standard costing. Fundamentally you operate on variances and manage those..not sure if they ever considered costing in a mixed mode which is what you seem to be looking for...
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Millicent Massey
Sent: Tuesday, March 13, 2012 3:27 PM
You are correct. Actual job cost is exactly what we are striving to get. Right now I do not have a standard cost on the sub-assemblies and I can't figure out a way to may this work the way we need it to work. I cannot maintain my five separate cost buckets based on what I am seeing in this module. I am truly at a loss here. I can't see how it's possible.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of pbparker
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Re: Job to Job transactions
If I'm reading you right, you're trying to do what we tried to do, which is bring actual costs from job to job, or even the assembly across to another job so you get a final job that shows what the total cost was to create a part.
You're probably finding that you're only getting the standard costs coming across, which is what we found also.
After talking to Epicor, if you use standard costed parts, the part will ALWAYS use the standard cost when it moves in a transaction. Therefore, we were told, there is no way to move ACTUAL costs from job to job if the part moving, or assembly, is in the system and is standard costed.
We were told to change all our component parts that may be moving to any other cost basis other than standard and that we could manage the costs - or override the cost at transfer time.
Not the answer we wanted, and we did not make all those changes - although we are considering it so we can get ACTUAL TRUE costs to manufacture a parent part.
Not sure if that's what you were asking.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Millicent Massey <millicent.massey@...> wrote:
> I am doing job to job transactions and I am having difficulty getting the expected results. We are doing standard cost and trying to utilize job to job to transfer material, labor, and all of the burdens without hitting stock. I cannot see how the labor would be transferred, is this possible on this screen? The second question would be if I am building sub-assemblies, is it possible to just transfer the sub-assembly and not the individual materials and still complete the transfer of costs?
> Mdm
Mdm
--- In vantage@yahoogroups.com, Millicent Massey <millicent.massey@...> wrote:
> Mdm
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of pbparker
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Millicent Massey <millicent.massey@...> wrote:
> Mdm
Wouldn't FIFO costing work for this? If you are using them as they are
being created I would think that should work. I would think average
costing would give you a pretty good idea as well.
Josh Serwe
Manager of Warehouse & Logistics
920.437.6400 Ext. 330
Safety
Professionalism
Effectiveness
Easy
Demand Results
_____
Of Millicent Massey
Behalf Of pbparker
create a part.
parent part.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> Mdm
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Millicent Massey
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of pbparker
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Millicent Massey <millicent.massey@...> wrote:
> Mdm
