In the past when all the records have been good and I can confirm it is just a display issue, then in my case I’ve not had any problems with simply closing the job.
When I have time to kill then (sometimes) I have been able to fix icon discrepancies by toggling values while saving records. Sorry I remember any specific field… just remember hunting and pecking and (eventually) hitting the right one.
Ref I attached copy and screenshot below of simple dashboard that I use
to check for simple stuff before I start playing around with value toggling.
worst case I will close the job with Exception. Just only I don’t want to create any costing trouble by doing this.
but I really wanted to know why system is showing like this? if its bug then EPICOR needs to fix it.
If you can verify the records are OK and what you are seeing is just a false positive/negative… then yes, a bug. I’ve run across this a few times in the past.
But… these can be very hard to reproduce - so that when I’ve contacted tech support in the past, they’ve not had much luck explaining/fixing.
Guessing these occur when either there was an odd entry sequence or some kind of interruption during processing that left some temp/calculated field populated… or not.
Which would explain why (sometimes) simply toggling/saving records can clear/reset the display.
I know I tracked down the cause of one issue by sitting and watching a users entry sequence… a long time ago so I can’t remember any specifics now.
