Job numbers
Hi All,
If I have a job numbered 1 and it makes part 1 after I close the job. Can I make a new job one year late called 1. We are thinking to have our job numbers the same as the part numbers
Thanks in advance
no, JobNum is unique.
What are you trying to achieve by having the job number as the part number?
It is easy to track. The job number matches the part number. I guess we could add a suffix say 1-1,1-2 etc.,
if the job is a make direct job linked to a sales order, the job number becomes the ordernum - line - release (ex 12345-1-1)
for the make to stock stuff its sequential numbers but in the Job table you can see what JobNum is making what PartNum. if you really need to see what job made what part once it hits inventory you will need to turn on lot tracking.
