Can someone point me in the right direction, we are looking for the following:
A dashboard that displays all jobs (oldest to newest) and goes down the list reporting if there is enough material to fill what jobs. For instance:
Job 1 requires 1 qty of part one
job 2 requires 3 qty of part one
job 3 requires 2 qty of part one
job 4 requires 1 qty of part one
We only have 5 part ones in stock so it would read okay on the first two line but not the 2nd two lines. We do use fulfillment workbench but ops is spending a lot of time trying to figure out how much inventory they have to completed x amount of jobs. Below is the exact request from ops. I am going to guess we cannot be the first company to do this, but i cannot find anything online that gets me close to the end goal.
Output with a column indicating “Ok” for all Materials are available vs “Short” for at least 1 Material is missing or not in sufficient supply.
Potentially look at the Fulfillment Workbench table data compared against the JobMtl table to see what materials are allocated/reserved vs what has not been allocated/reserved.
If [#2] is not doable, then look at OnHand, available (Not Non-Nettable) inventory and do a running subtotal of requirements (oldest Job first) and indicate at which Job Number the Material runs out.
Desired output would be a list of items which are not in sufficient supply (Req Qty < Allocated/Reserved Qty), grouped by Job Number. If all Job Materials are available, then a single row with a status of “Ok”.
