Job Efficiency % on Production Detail Report
Sure. Send it to ross(dot)hughes(at)comcast.net
Ross
Marty
Sent: Thursday, April 23, 2009 9:17 AM
Subject: [Vantage] Re: Job Efficiency % on Production Detail Report
Ross
Can I e-mail you the Production Detail Report I am looking at if you have
time to review it to see what I might be doing wrong to verify the vantage
Eff #.
If yes what e-mail address should I send it to
Marty
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> I can believe that.
> I am only trying to point to where the calculation is coming from in the
> Production Detail report that he is wrestling with.
> Ross
Of
> Todd Caughey
> Sent: Thursday, April 23, 2009 8:33 AM
> Subject: RE: [Vantage] Re: Job Efficiency % on Production Detail Report
> Earned Hours can be off too (in 6.10 anyway). Many times when I manually
> calculate it using the exact formulas given it will not match the value on
> the Labor Detail. Working with Support our best guess was something in
> Labor Edit was depositing incorrect info. But I had many cases where the
> Earned Hours manually calculated should have been 8 hours and the value in
> the system was randomly wrong...like 14.3 hrs, even when the quantity
> produced was almost exactly as estimated. Since it was easy enough to
> calculate it myself (and 6.10 will never be patched again) I just stopped
> using the value in the system. I hope this has been fixed in later
versions
> but since it was never acknowledged as a bug it probably wasn't..
> -Todd C.
Of
> Ross Hughes
> Sent: Thursday, April 23, 2009 8:16 AM
> You may want to look in to earned hours. Although the report may not
> display this in the detail the formula at the bottom is calculating from
> this and this is a hidden field in the report.
> Here are the earned hour calcs:
> For Production:
> If the Run quantity > 0: EarnedHrs = EstProdHours / RunQty x LaborQty
> If the Production Standard is fixed hours: EarnedHrs <= EstSetHours -
> ActSetHours + SetReworkHours - Burden Hours for this labor detail record
> If the operation quantity = 1: EarnedHrs = Operation Hrs Remaining
> (EstProdHours - ActProdHours) or Hours Worked (BurdenHrs), whichever is
less
> For Setup:
> Setup Not Complete: EarnedHrs = EstSetHours x SetupPctComplete or
> ActSetupHours, whichever is less
> Setup Complete: EarnedHrs = EstSetHours - ActSetHours + SetReworkHours -
> Do this math on the detail and then see if the numbers make more sense.
> Or provide more detail and I can try to help with the calculations. Your
> labor detail records should have the earned hours in them as they are
> calculated through the business logic.
> Ross
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
Behalf
> Of
> Marty
> Sent: Thursday, April 23, 2009 7:32 AM
> Let me line up the hours better..when I used preview it looked ok the
first
> time I posted it
> Estimated Hours
> Setup __ 1.80
> Prod __ 0.49
> Actual Hours
> Setup __ 0.42
> Prod __ 0.93
> Eff. Pct: 54.15
> I can't figure out where the 54.15 is coming from..
> This is at the end of the report just about the Profitability Area of the
> report
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Marty"
> <marty1325@> wrote:
> > I also thought it might NOT be using Setup to calculate the percentage
but
> that didn't work either..
> > Here are the #'s I am seeing on my Report (at end of report where I
assume
> its recaping the detail hours)
> > Est Hours Actual Hours
> > Setup 1.80 .42
> > Prod .49 .93 Eff Pct: 54.15
> > I am Sooo Confused...
> > thanks.
> > Marty
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Robert
> Brown <robertb_versa@> wrote:
> > > Look at LaborDetail to see if there is an estimate cost versus actual
> cost bucket (not hours). It could be doing dollar math (and actual dollars
> aren't always one to one with hours if you split burden, etc,).
> > > Another crazy possibility: Set up is non-value added cost. See if the
> %'s add up with set up left out.
> > > Rob
> > > --- On Wed, 4/22/09, Marty <marty1325@> wrote:
> > > From: Marty <marty1325@>
> > > Subject: [Vantage] Job Efficiency % on Production Detail Report
> > > Date: Wednesday, April 22, 2009, 4:11 PM
> > > I am trying to figure out how vantage Calculates this # at the end of
> the Production Detail Report.
> > > The Heading is ASM Totals (job # after it)
> > > I am not talking for each of the operations. But at the end of the
> report where it says Estimated Setup and Production Hours and next to it
> Actual Setup and Production hours are listed
> > > One would think all you would do is to add the Estimated Setup and
> Production Hours and divide by the Actuals.
> > > But NO...I can't get it to even come close doing it that way.
> > > What Vantage logic am I missing here.
> > > Thanks....
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
have
I am trying to figure out how vantage Calculates this # at the end of the Production Detail Report.
I am not talking for each of the operations. But at the end of the report where it says Estimated Setup and Production Hours and next to it Actual Setup and Production hours are listed
One would think all you would do is to add the Estimated Setup and Production Hours and divide by the Actuals.
Thanks....
It uses Earned Hours. If I am in the place you are referring to then the
crystal formula is:
if Sum ({JobOper.ActProdHours})= 0 then 0 else
(Sum ({@EarnedHours})) / (Sum ({JobOper.ActProdHours}))* 100
Ross
Marty
Sent: Wednesday, April 22, 2009 3:11 PM
Thanks....
Look at LaborDetail to see if there is an estimate cost versus actual cost bucket (not hours). It could be doing dollar math (and actual dollars aren't always one to one with hours if you split burden, etc,).
Another crazy possibility: Set up is non-value added cost. See if the %'s add up with set up left out.
Rob
Thanks....
Thanks Ross. My hunch that set up might be ignored seems to have been correct (bravo to Epicor for a change!)
Ron
--- On Wed, 4/22/09, Ross Hughes <ross.hughes@...> wrote:
Subject: RE: [Vantage] Job Efficiency % on Production Detail Report
Date: Wednesday, April 22, 2009, 4:57 PM
crystal formula is:
if Sum ({JobOper.ActProdHo urs})= 0 then 0 else
(Sum ({@EarnedHours} )) / (Sum ({JobOper.ActProdHo urs}))* 100
Ross
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Marty
To: vantage@yahoogroups .com
Thanks....
http://groups. yahoo.com/ group/vantage/ files/.
http://groups. yahoo.com/ group/vantage/ messages
http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
I also thought it might NOT be using Setup to calculate the percentage but that didn't work either..
Here are the #'s I am seeing on my Report (at end of report where I assume its recaping the detail hours)
Setup 1.80 .42
thanks.
Marty
> Rob
> From: Marty <marty1325@...>
> Thanks....
Let me line up the hours better..when I used preview it looked ok the first time I posted it
Estimated Hours
Setup __ 1.80
Prod __ 0.49
Actual Hours
Setup __ 0.42
Prod __ 0.93
Eff. Pct: 54.15
This is at the end of the report just about the Profitability Area of the report
> Setup 1.80 .42
> thanks.
> Marty
> > Rob
> > Thanks....
I think these might be rounding vs. truncating issues in display and calculation also. I think I played around with this some years ago and satisfied myself that's what was happening but I don't remember exactly. As I recall, estimated and/or actual hours were the total of truncated and/or rounded values but the eff. pct calculation was totaling each instance of these hours out to 15 or so decimal places and calculating from there (or vise versa).
Greg
----- Original Message -----
Sent: Thursday, April 23, 2009 7:31 AM
Estimated Hours
Setup __ 1.80
Prod __ 0.49
Actual Hours
Setup __ 0.42
Prod __ 0.93
Eff. Pct: 54.15
> Setup 1.80 .42
> thanks.
> Marty
> > Rob
> > Thanks....
For Production:
(EstProdHours - ActProdHours) or Hours Worked (BurdenHrs), whichever is less
For Setup:
Ross
Marty
time I posted it
Estimated Hours
Setup __ 1.80
Prod __ 0.49
Actual Hours
Setup __ 0.42
Prod __ 0.93
Eff. Pct: 54.15
report
> Setup 1.80 .42
> thanks.
> Marty
> > Rob
> > Thanks....
Earned Hours can be off too (in 6.10 anyway). Many times when I manually calculate it using the exact formulas given it will not match the value on the Labor Detail. Working with Support our best guess was something in Labor Edit was depositing incorrect info. But I had many cases where the Earned Hours manually calculated should have been 8 hours and the value in the system was randomly wrong...like 14.3 hrs, even when the quantity produced was almost exactly as estimated. Since it was easy enough to calculate it myself (and 6.10 will never be patched again) I just stopped using the value in the system. I hope this has been fixed in later versions but since it was never acknowledged as a bug it probably wasn't..
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ross Hughes
For Production:
For Setup:
Ross
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Marty
time I posted it
Estimated Hours
Setup __ 1.80
Prod __ 0.49
Actual Hours
Setup __ 0.42
Prod __ 0.93
Eff. Pct: 54.15
report
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Marty" <marty1325@...> wrote:
> Setup 1.80 .42
> thanks.
> Marty
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Robert Brown <robertb_versa@> wrote:
> > Rob
> > Thanks....
I can believe that.
Ross
Todd Caughey
-Todd C.
Ross Hughes
For Production:
For Setup:
Ross
Of
Marty
time I posted it
Estimated Hours
Setup __ 1.80
Prod __ 0.49
Actual Hours
Setup __ 0.42
Prod __ 0.93
Eff. Pct: 54.15
report
> Setup 1.80 .42
> thanks.
> Marty
> > Rob
> > Thanks....
Ross
Can I e-mail you the Production Detail Report I am looking at if you have time to review it to see what I might be doing wrong to verify the vantage Eff #.
Marty
> I can believe that.
> Ross
> Todd Caughey
> -Todd C.
> Ross Hughes
> For Production:
> For Setup:
> Ross
> Of
> Marty
> time I posted it
> Estimated Hours
> Setup __ 1.80
> Prod __ 0.49
> Actual Hours
> Setup __ 0.42
> Prod __ 0.93
> Eff. Pct: 54.15
> report
> > Setup 1.80 .42
> > thanks.
> > Marty
> > > Rob
> > > Thanks....
