Job Batching with Job-to-Job demand link
10.2.500
Client makes store fixtures, MOMs for final assemblies have several ViewAsAssembly subassemblies that are made on separate jobs with Job-to-Job demand links. They want to use Job Batching on these subassemblies (which often have identical BOOs). Everything works great up to the “Auto Receive” point… they still have to manually do the Job Receipt to Job transactions.
The Education document only talks about Auto Receive creating automatic receipts to Inventory. Is this a limitation of the functionality, or is there something else we should look at?
What seems to have solved the problem is…
When you create the Final Assembly job, select Make Direct on each subassembly that will become batched BEFORE you create the Batch jobs.
Although we’ll test this further, it’s looking good. Thanks for listening!
I JUST completed the first batch we ever did, and it auto issued the parts from the batch job to the original. We also had Final Operation checked off on the operation.
