Hi All,
I have created a BOM and check it in.
I have created a job from the BOM.
I change the BOM checked out and in
The job does not update, am i missing something ?
Job is a snapshot of an approved revision at the time the job is created. It is not connected to a revision.
If you want the changes to be reflected, you need to delete everything on the job (right click on the top level part, and click clear all) then get details again.
Jobs give you the freedom to make changes on a specific job, but that means you also have the responsibility to make any necessary changes.
Thanks for the replies
