Item Master Data (Batch or Serial number control)
Hi , I am new to EPICOR . How to amend item master data mainly Serial Control or Lot control after procurement transaction happened?
We have several parts which were either define incorrectly or nor defined at all tractability field ( Batch or Sr control) initially , we procured them and transacted.
Now , after realizing mistake we want to correct them all or define right field (Batch or Sr control). Can someone advise correct and most efficient way to do it.? ( Just keep in mind all parts are now in inventory just received it but no further transaction done after that)
Erpfan
You can adjust out the inventory, then change the part to lot/serial track, then adjust it back in using the lot/serial#.
Thank you Jeff.
Erpfan.
