We are currently wrestling with this problem. We are subject to nuclear
codes which require our traveler to be a contolled document. For each copy
of the traveler we must track its location and rev at all times. We want
traveler info available to many people thru pc's but we want to disable
printing or editing. The activity log is nice but only helps AFTER a
potential problem has been found, (like an edit to a traveler). This could
cost us hundreds of thousands. Unfortunately the only method we see is to
severely limit the access to the traveler in vantage and create new reports
to supply the traveler info to the majority of users. I have been working
on building a traveler to mimic the vantage traveler. What a pain!!
Another idea we are discussing is using colored paper for all controlled
documents. This needs to meet customer approval. It also means locking up
the paper or using a dedicated printer in a secure location.
Mark Dupuis
Ranor Inc.
Sent: Thursday, November 15, 2001 11:19 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] ISO/Vantage Question
It would seem to me that the traveler is already a controlled document, in
that only MFG part revisions in vantage that have been approved by the
appropriate personell make it onto the job, and onto the traveler. Whenever
a traveler is printed, it is a representation of the current approved job
records in vantage.
However, once the traveler is on the floor, the data in vantage could
change, and the traveler is then not the current revision....
Sent: Thursday, November 15, 2001 7:03 AM
We are also ISO certified. Our blueprints are controlled documents but our
travelers are uncontrolled. We limit access to them and the person who
prints the traveler does initial it but it is not a controlled document in
comparison to the blueprints. This was enough to satisfy our auditor.
You have to be careful with the word Controlled. In a strict sense a
controlled document is tracked by revision level, with a change history, and
control of where it is at any given time. Under ISO Document Control you
don't want to have a previous revision in use after a newer revision has
been released.
Obviously, this could be difficult for a job traveler which is always
subject to change due to scheduling changes, different work center,
different job standard, etc. Just initialing the traveler was sufficient
for our auditor. But our prints, reference documents, ISO Manual, ISO
Procedures and Work Instructions are held to the higher standard. As
Patrick said, push for what makes the most sense for you.
Mitchell Kirby
m.kirby@...
Sent: Wednesday, November 14, 2001 6:01 PM
In our case, customers required that our travelers be CONTROLLED. So I
just added a box at the bottom for the initials of whoever approved the
traveler. Also, you could use the Vantage user fields for this info-even
numeric fields would be ok as long as you have a list somewhere of what
number corresponds to what person. There is also that darn "Job Code"
that's down in the corner of the Job Header. I've never been able to come
up with a reliable scheme for using this code, so it is always blank, but
now that I think of it, we could use that for approvals.
Lydia Coffman
lcoffman@...
Sent: Wednesday, November 14, 2001 1:19 PM
We are ISO9002 and QS9000 certified. Adding details such as "APPROVED BY:"
and "PREPARED BY:" to the Job Traveler sound like someone is trying to make
it a CONTROLLED document. See if you can make it UNCONTROLLED. We generally
made our electronic media such as prints or job routings the MASTER or
CONTROLLED originals we said anything printed out on paper is uncontrolled.
There were a few exceptions of course. Such as we control two printed out
versions of our manual. The most important thing to remember when getting
certified is challenging all these little changes with "Does is make sense
from a business stand point for us to do this?"
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.00.317, Progress 9.1a
Sent: Wednesday, November 14, 2001 2:58 PM
Subject: [Vantage] ISO/Vantage Question
We are being strong armed by some of our customers to be ISO certified.
In doing some preliminary assesments I have been told that I need to add
"APPROVED BY:" and "PREPARED BY" information to the Job Travelers. I was
informed that this information should come from the person who approves the
revision. When I look at the traveler form, I do not see where this
information is available to me to add to the traveler.
I am sure this is just one of many issues I will have on this subject but
I can't help but believe that there are some of you out there that have been
through this process and can tell me what to do or at least send me down the
right path.
I appreciate any insite that you may be able to give me.
Colette Nunn
Director of Computer Services
East Moline Metal Products
1201 7th Street
East Moline, IL 61244
Phone 309-752-1381
Fax: 309-752-1382
Email: cnunn@...
Mark Dupuis
Ranor Inc.
records in vantage.
been released.
Mitchell Kirby
m.kirby@...
Lydia Coffman
lcoffman@...
Patrick Winter
right path.
Colette Nunn
1201 7th Street
Phone 309-752-1381
Fax: 309-752-1382
Email: cnunn@...
