Scenario is following.
User is clicking a button in Kinetic App. App is doing some validations and if needed I would like to show a pop-up with text-box where user can type some info and click OK.
Is there any widget that can do that for me or I need to do it differently - how?
Does BPM form can be called directly from Application Studio or I need to call first a BO,method that BPM form will be tied to? Sounds like complex way of getting info from user.
Be my guest and please do it.
I lost faith in Epicor long time ago regarding submitting anything as it takes ages before anything will be done.
Regarding “low hanging fruits” you mentioned about - I think if such thing will happen then this is just a coincidence - they already planned to release something while you are thinking you were lucky.
BTW for this particular case, slider work perfectly fine for me and can be customized as needed. What I wasn’t able to do with slider was to make a title/description for slider and for panel card dynamic - but this is different story.
