I am running 10.1.500.8 and I created a BAQ that shows the history of orders for a customer.
I would like to add a sheet to the Order Entry form that I can use to display the output of the BAQ I created (based on the custnum of the sales order entered).
I have seen this done from one of my customers - so I know it can be done. However, I was hoping someone here could coach me on how to do a simple example.
I am not a C# programmer - so please excuse my newbie questions.
Yes, we did this at a previous employer. Create the dashboard and then in
customization mode add the sheet to the tab layer you want. I would look at
the ice manual or is it user experience guide for the details. We set the
new sheet to require a retrieve button so the order screen doesnât bog down
every time you change to a different order/customer.
I would recommend what Brad said⌠Create your BAQ⌠Create a Dashboard probably Updatable and then inside your Customization under Tabs you can Add Dashboard⌠Then you can continue to Customize it on your UI layer⌠Let Epicor handle building the Grid, BAQ etc⌠if possible⌠you dont need the extra 500 lines of code that come with building your own Grid.
Create a tab and add it to the Sales Order Entry Screen. Then create a
dashboard for your BAQ. Then Add the dashboard to the new tab you created
through the screen below
From that I was able to distill the bare code down to:
private void epiButtonC1_Click(object sender, System.EventArgs args)
DynamicQueryAdapter dqa = new DynamicQueryAdapter(oTrans);
dqa.BOConnect();
dqa.ExecuteByID(â02-DeleteMe2â);
epiUltraGridC1.DataSource = dqa.QueryResults.Tables[âResultsâ];
