I would like a list of all standard menu items that can be configured through Menu Maintenance. I want to paste the list into excel so I can then use my security groups to secure each menu item. I understand I can expand them all then type them out into excel, but does anyone have this information already?
And there’s a very Excel un-friendly report that can be run on Sec Groups, Users or SecurityID’s(which are used by the menus) In System Management Security
As well, you can create two calculated fields for:
*OptionType:*
case Menu.OptionType
when 'S' then 'Sub Menu'
when 'I' then 'Menu Item (Program)'
when 'B' then 'Report Builder'
when 'D' then 'Dashboard'
when 'A' then 'BAQ Report'
when 'U' then 'User Defined'
when 'C' then 'Dashboard-Assembly'
when 'N' then 'Non Menu Item'
when 'E' then 'External Process'
when 'M' then 'Mobile Dashboard'
else Menu.OptionType
*SubType:*
case Menu.OptionSubType
when 'F' then 'Form'
when 'T' then 'Tracker'
when 'M' then 'Maintenance'
when 'P' then 'Process'
when 'R' then 'Report'
when 'E' then 'Entry'
when 'C' then 'Custom Dashboard'
else Menu.OptionSubType
end
I usually run this SQL query if I’m looking for a customization, and because of the way I sequence it, it show everything in order from top to bottom. The limitation is it only shows menu items that are EXACTLY four levels deep ( Example: Sales Management -> Quote Management -> Setup -> Role Code). But for my purposes, it does the trick.
I usually have another line in my query, such as 'm1.Program = ‘Erp.UI.JobTracker.dll’ which I use to show everywhere Job Tracker runs. You may want to use this as a starting point.
select m4.menudesc, m3.menudesc, m2.menudesc, m1.menudesc, m1.Sequence,
m1.Program, m1.Arguments
from ice.menu m1, ice.menu m2, ice.menu m3, ice.menu m4
where m1.ParentMenuID = m2.MenuID
and m2.ParentMenuID = m3.MenuID
and m3.ParentMenuID = m4.MenuID
and m4.ParentMenuID = 'MAINMENU'
order by m4.Sequence, m3.Sequence, m2.Sequence, m1.Sequence
