Len,
Hope all is well, sorry for the delay, I was out for most of the day...
No the cards we're looking at are about 7K. They are the 160GB single versions, not the multi...
The single cell are 40 percent faster & more reliable.
Ron Flynn
Cubic Designs, Inc.
CUSTOM MEZZANINE SYSTEMS
16770 West Victor Road
New Berlin, WI 53151
262.789.1966 xt. 124
262.789.1970 fax
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Len Hartka
Sent: Wednesday, February 03, 2010 10:19 AM
Subject: Iodrives : RE: [Vantage] Re: Vantage getting slower by the week.
Good Day Ron:
I could not come up with a good term for the Iodrive - Solid state
flash memory is good.
You may well be OK with that since one vendor said the Iodrive is
the equivalent of 100-500 "Spindles"; whereas a 24-disc Array is just 24
spindles.
Do the Iodrives still cost $15,000?
Len
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of IT Support
Sent: Tuesday, February 02, 2010 3:47 PM
Subject: RE: [Vantage] Re: Vantage getting slower by the week.
Len,
We currently only have a PE2900 @ 2x 2.0GHz with 24GB memory.
We are only a 30 user company, with 20 consistent users thru out the
day.
Vantage 803.408B is running quite well for us now (performance wise) &
we did a pretty good analysis of our server when we had the performance
issues.
After every test we did, no matter what time of day or how many users
were on the system, the only taxed part of the server was the disk IO.
I know we are not optimal in this area as well... we really should have
another RAID 10 volume, but things are running well.
We are considered a "small" Vantage customer I guess & separating
Progress off onto another server would be overkill for us.
When we move the R710, we will be gaining quite a bit; 1 thousand MHz
per CPU, the new 1333 memory architecture, the ioDrive, & 64bit server
OS.
The ioDrive is not SSD, but solid-state flash memory. It's really quite
impressive.
I guess if we are not satisfied after the move to 9.05 with that setup,
we'll just wait for 10.0 & try again... J
Ron Flynn
Cubic Designs, Inc.
262.789.1970 fax
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Len Hartka
Sent: Tuesday, February 02, 2010 1:40 PM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Good Day Ron:
A R710?
For 75-100 users, we have three R710's plus a 24 drive array.
Of course, we did NOT get the iodrivecard - I assume that is the
"SSD unit" that plugs right into the PCI slot on the motherboard. I
know it as an IOmega device.
len.hartka@... <mailto:len.hartka%40sunautomation.com> <mailto:len.hartka%40sunautomation.com>
Behalf
Of IT Support
Sent: Tuesday, February 02, 2010 1:27 PM
Charlie,
I never had the opportunity to attend that class, however even though it
was after the fact,
I attended the admin/performance class at Perspectives & that's all they
stated as well.
When we go to Epicor 9.05, we are going a different route yet again.
We will be going with a R710 maxed out and using a ioDrive160 card to
handle the DB's.
Due to 2009 being such a poor year, we were not able to make any
hardware improvements, but things are getting better to the point
That we do not want to make that mistake again in 2010 for Epicor 9.
A fellow group member brought up the card & after thorough conversations
with our consultants & ioFusion we feel for the money there isn't a
better solution.
1 caveat though is that the card is not currently bootable, so we will
have the OS on a RAID 1 volume & everything else on the card.
Ron Flynn
Cubic Designs, Inc.
262.789.1970 fax
Behalf
Of Charlie Wilson
Sent: Tuesday, February 02, 2010 12:15 PM
Depending on how many drives are in the array of a raid 10 you can
double
and quadrpel read and write rates. This is due to the fact that the raid
is
a stripe across multiple mirrors which means you can write a string
sectors
at once basically. There are 1000 and white paper reports about raid
configurations you can go read. But I can't believe that was epicors
recommendation. I went to the admin class and it was raid 10 raid 10
raid 10
I had to make sure it wasn't tattooed on me somewhere before I left.
~Charlie
_____
Behalf Of
IT Support
Sent: Tuesday, February 02, 2010 1:02 PM
I'm with Charlie if that's true...
We had severe performance issues & installed a RAID 10 volume for the
DB & have seen a much improved performance increase.
People actually comment on how well Vantage is running, which was NEVER
the case before.
We were only able to add a single 3x3 RAID 10 (15K Drives) due to
chassis limitations, otherwise I would have added a second set like
suggested for the transaction logs...
Also, our consultants did a very thorough tuning of the entire server...
We are a 30 user SQL environment.
Ron Flynn
Cubic Designs, Inc.
262.789.1970 fax
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
Sent: Tuesday, February 02, 2010 11:53 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
And everything is on this raid 1?
~Charlie
_____
Behalf Of
mmcwilliams22
Sent: Tuesday, February 02, 2010 12:42 PM
Subject: [Vantage] Re: Vantage getting slower by the week.
Dual Xeon 2.8 with 4GB of RAM 15k disks
Windows 2003 Server
15 Shop Floor
25 Office users
Antivirus is ESET with all the recommended exlusions.
Volume shadow copy is not enabled.
Indexing is disabled.
I defragged the server on Sunday yet still have 60% file & 30% total.
Vantage is backed up at 2a, 6a, 10a, 4p & then also uploaded to an
offsite
location.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
Michael
Barry <mbarry@...> wrote:
concurrent
users including shop floor? I'm assuming that you are running some
variant
of Windows Server so do you have things like volume shadow copy or the
indexing service running? Is there a periodic disk defragmenter or
online
backup process running?
<http://www.aspacia.com/ <http://www.aspacia.com/> > >
com/>
com/
addressee(s) named herein and may contain legally privileged and/or
confidential information. If you are not the intended recipient of this
email, you are hereby notified that any dissemination, distribution or
copying of this email, and any attachments thereto, is strictly
prohibited.
If you have received this email in error, please immediately notify me
by
telephone and permanently delete the original and any copy of any email
and
any printout thereof.
user may be in AP invoice entry and all the sudden they start getting
"Not
Responding" and it takes a minute for a new line to appear and then 30
minutes later it is just cruising along. We are using 15k drives in RAID
1,
I am sure that has some to do with it. But will RAID 10 really make that
much of a difference & if that is the case then maybe SSD is really
worth
looking into. If I knew where to pinpoint I could throw the resources at
it.
Behalf
not
for
This e-mail and any attachments may contain proprietary and/or
confidential information. If you are not the intended recipient, please
notify the sender immediately by reply e-mail or at 410-472-2900 and
then delete the message without using, disseminating, or copying this
message or any portion thereof. With e-mail communications you are urged
to protect against viruses.
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Ron Flynn
Cubic Designs, Inc.
262.789.1970 fax
Good Day Ron:
spindles.
Len
Of IT Support
Len,
day.
issues.
OS.
impressive.
Ron Flynn
Cubic Designs, Inc.
262.789.1970 fax
Behalf
Of Len Hartka
Good Day Ron:
A R710?
Behalf
Of IT Support
Charlie,
was after the fact,
stated as well.
handle the DB's.
better solution.
Ron Flynn
Cubic Designs, Inc.
262.789.1970 fax
Behalf
Of Charlie Wilson
double
is
sectors
raid 10
~Charlie
_____
Behalf Of
IT Support
the case before.
Ron Flynn
Cubic Designs, Inc.
262.789.1970 fax
Behalf
Of Charlie Wilson
~Charlie
_____
Behalf Of
mmcwilliams22
Windows 2003 Server
15 Shop Floor
25 Office users
offsite
location.
Michael
>configured? I got the RAID 1 but what about CPU/RAM etc? How many
> Sorry, I left out a couple of additional questions. How is your server
concurrent
variant
online
> Regards,
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> http://www.aspacia <http://www.aspacia <http://www.aspacia.com/
com/>
com/
>the
> This email, and any attachments thereto, is intended only for use by
prohibited.
by
and
>A
> On Feb 2, 2010, at 9:17 AM, mmcwilliams22 wrote:
> > Yes. The thing is that it is not only ODBC, it is the whole system.
"Not
1,
worth
it.
> > > Is your DSN setup for "Read Uncommitted"?
> > > Thanks,
> > > Blake Clemens
> > > IT Systems Engineer
> > > Delmarva Millwork Corporation
> > > (800) 360-2364 x132
Behalf
> > > Of mmcwilliams22<mailto:vantage%40yahoogroups.com> ,
> > > Sent: Tuesday, February 02, 2010 12:00 PM
> > > 11.5.3
> > > "Blake Clemens" <blake.clemens@> wrote:I'm
> > > > What version of Crystal are you using to design your reports?
not
> > > > talking about the Crystal version on each client machine..com
> > > > Thanks,
> > > > Blake Clemens
> > > > IT Systems Engineer
> > > > (800) 360-2364 x132
> > > [mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com>.com
> > > Behalf<mailto:vantage%40yahoogroups.com>
> > > > Of mmcwilliams22
> > > > Sent: Tuesday, February 02, 2010 11:50 AM
> > > > Subject: [Vantage] Re: Vantage getting slower by the week..com
> > > > 408
> > > <mailto:vantage%40yahoogroups.com> ,.com
> > > > > What version of Vantage are you on?
> > > > > Thanks,
> > > > > Blake Clemens
> > > > > IT Systems Engineer
> > > > > (800) 360-2364 x132
> > > <mailto:vantage%40yahoogroups.com> ] On.com
> > > > Behalf
> > > > > Of mmcwilliams22
> > > > > Sent: Tuesday, February 02, 2010 11:43 AM
> > > <mailto:vantage%40yahoogroups.com>cannot
> > > > > Subject: [Vantage] Vantage getting slower by the week.
> > > > > I am working on increasing the performance of Vantage but
> > > seemCPU
> > > > to
> > > > > find the bottleneck. At times when users are complainaing the
> > > > > utilization is at 1% on server and less than 3% on client.Memory
> > > > usagethe
> > > > > is not a factor at all, we are not even close on the client &
> > > > serverlook
> > > > > has about 1gig free room. I ran wireshark on the clients to
for
> > > > tcpODBC
> > > > > retransmits or packet loss & no problems there. Some times an
> > > > > report will take 10 seconds and then a few minutes later 3minutes,
> > > > butDate:
> > > > > I cannot pinpoint what is causing the performance issue.
> > > > > No virus found in this incoming message.
> > > > > Checked by AVG - www.avg.com
> > > > > Version: 9.0.733 / Virus Database: 271.1.1/2662 - Release
> > > > 02/02/1002/02/10
> > > > > 02:35:00
> > > > Version: 9.0.733 / Virus Database: 271.1.1/2662 - Release Date:
> > > 02/02/10
> > > > 02:35:00
> > > 02:35:00[Non-text portions of this message have been removed]
